Help with Stereo Install on '95 Talari 180
Old 05-21-2014, 08:22 PM   #1
scb8mp is currently offline
Send scb8mp:
Default Help with Stereo Install on '95 Talari 180
I just bought a 1995 Talari and the head unit that was once in the boat is missing. It still has two 6.5" speakers under the port and starboard consoles. I'd like to install a new head unit, but I'm unsure where to start with the wiring. There is a mess of wires going into the fuse box, but nothing is labeled. Does anyone have experience with this or a wiring diagram?
  • Old 05-21-2014, 09:55 PM   #2
    Default Re: Help with Stereo Install on '95 Talari 180
    Have you checked for the stereo wiring harness down inside where the stereo is mounted? Mariah always labeled their wiring so unless someone cut it off it should be there.
    Old 05-21-2014, 10:16 PM   #3
    Send scb8mp:
    Ahh, I guess I just needed to look harder. So I take it that if I buy a new stereo, it will come with a different wiring harness and I'll have to cut the old one off and match up all of the wires?
    Old 05-21-2014, 10:30 PM   #4
    Buy a Kenwood , Alpine , or Pioneer head unit and it is plug and play.
    Old 05-22-2014, 12:33 AM   #5
    Send scb8mp:
    That's an awesome tip, thanks guys
    Old 05-28-2014, 10:26 PM   #6
    Send scb8mp:
    So I took your advice, an bought a new Kenwood marine stereo. Installation was super easy, the harness was plug and play as promised. The problem is that even with the volume all the way up, the speakers sound super quiet. I wasn't expecting home theater level sound quality, but you can barely hear the audio with the volume cranked up to max.
    I'm using the original speakers that came with the boat, so they could very well be bad. Does this sound like a problem with the speakers or something wrong with the stereo installation? I already played around with the Fade/Balance settings and couldn't make it sound any better.
    Old 05-28-2014, 10:53 PM   #7
    I'd say speakers too , but did you make sure the wiring for the speakers (+ & -) are connected right?
    Just a thought........does the deck have mute? Maybe it is on.
    Old 05-29-2014, 02:19 AM   #8
    Send scb8mp:
    Don't think there is any mute setting on. Could this type of problem be caused by a bad ground?
    Old 05-29-2014, 02:26 AM   #9
    doaclnr is currently offline
    My Model: Z302
    My Engine: Volvo Penta 8.2 DP
    Send doaclnr:
    Check for an amp somewhere. I had that problem and found a bad amp.
    doaclnr
    99 Z302 8.2 DP
    Old 05-29-2014, 02:31 AM   #10
    Send scb8mp:
    Shouldn't I just be able to bypass the amp, and run the speakers right off the head unit? The one I have is the KMR-308 and it's rated for 22W RMS x 4. Should be plenty to power a couple of small 5" speakers.
    Carpet install 95 talari 180 Jhern523 General Maintenance 4 05-08-2014 03:22 AM
    Wanted: Looking for Molded trim around stereo panel for 95 Z200 talari MACH 1 Mariah Parts For Sale & Wanted 11 05-22-2012 08:09 PM
    1995 z190 talari wake tower install tweir Watersports 0 07-19-2011 03:53 AM
    Almost done with A/V Install! Z275 Original Mariah Talk 4 04-14-2008 07:46 PM
    There are 475 users
