-   -   Z275 ST Value?????????? (http://www.mariahownersclub.com/forum/original-mariah-talk/9193-z275-st-value.html)
mikeyt 04-15-2014 08:39 PM
Re: Z275 ST Value??????????
Check out Boattrader.com I see a 2001 there for $30.5k in Tennessee. Of course the theme from Deliverance will be the only thing playing on your radio.... ;)
mhelt 04-15-2014 08:50 PM
Yea i just discovered it this afternoon. It seems i have struck a deal with the owner. Well atleast i hope since i have already ordered an extended swimplatform from swimplatforms.com. Judging the history of the boat the current market trends and from what i have seen ones listed for i feel like im getting into the boat right. defintely not a steal. Hopefully someone on here will like it in a year or two when im ready to go fast again. Im guessing in 2years i will still be under the 300 hr mark but no promises. I get lost alot and alcohol induced internal gps system likes the long way home.:drunk:
z275st 04-16-2014 02:03 AM
Na!! You won't want to git rid of it in a year or two. It is one of the most versatile boats you can own. my only complaint is the fridge will quickly drain batteries even set on low so I unplugged mine and use it as another cooler. As for price, it sounds like you are getting a fair or better deal, since a boat in excellent shape demands a better price. Just go to any manufacture website and build one similar to it and see the list price. I have and it would be well over a $100,000 boat!!!
Enjoy:wink_thumbup:
mhelt 04-16-2014 12:57 PM
Not to go off topic but the comment about the refrigerator. Where does it unplug at? I have no reason to use the refigerator and currently all batteries are deader than a hammer. Im still digging through the compartments looking for any possibilities of other shut off switches. Also going even further off topic it has the 496 mag ho and it is currently winterized. What steps would i take to unwinterize?
:confused:
z275st 04-16-2014 09:19 PM
mhelt,
I found no switch only for the fridge so I unplugged it. It has two wires about 12 inches long coming out of it in the back. When I first got the boat the house battery and two starters would die very quickly. I finely found it was the problem. It will hold extra ice all day long. I often freeze 5-6 bottles of water and place in it with lunch meat and candy bars to keep cool all day. If you open the fridge and unscrew the trim screws and pull out the fridge, you can stuff insulation around and bottom of the molded in cooler above it. You will find by doing this ice and cold drinks will last much longer on hot days!
As for starting in spring: make sure all hoses are connected and 2 blue screw-plugs/stopcocks on water pump (lower left front of engine) are there and tight. If you have closed cooling sys. (you will have antifreeze tank if you do) pull up on the ring-pin on the right front top of engine and make sure it goes all the way in/down or water will pump into bilge while the engine is running. This can lead to a couple hours of trying to find out where water is coming from while you could otherwise be boating (Or so I have heard:mallet_on_head:).
Back the boat deep into the water or use garden hose for pressure with earmuffs on lower unit to start first time.
