Water dam in the hull?
Old 03-30-2014, 03:22 AM   #1
jetinspector's Avatar
jetinspector is currently offline
My Year: 1990
My Model: 2000Z
My Engine: Mercrusier 350
Send jetinspector:
Default Water dam in the hull?
I will see if I can get a picture to attach but I have a build up of fiberglass at the bottom of the hull right infront of the bilge pump and it keeps water in the boat that I cannot get to drain. Do any other models have this and what do you do about it? It can't be good to let the water just sit in there!
  • Old 03-30-2014, 05:08 AM   #2
    Default Re: Water dam in the hull?
    I have the same thing on the Diablo jet.
    My bilge mounts on top of it on the Diablo.
    I just use a towel to soak up the water that is left. Could be a pain in a larger boat.
    Surprised they didn't have a small pipe running thru the block.
    Here is the best pic I got of it when I was doing my engine replace.
    Old 03-30-2014, 05:24 AM   #3
    My Year: 1990
    My Model: 2000Z
    Send jetinspector:
    I have thought about gluing some kind of a tube there to go around it but then the tube would just plug up and become useless!
    Sent from my SCH-I535 using Tapatalk
    Thru Hull Transducer 300sflyer Original Mariah Talk 4 09-28-2010 02:20 PM
    composite Hull jktbea Original Mariah Talk 2 08-06-2010 10:56 PM
    I this the same hull CARL SWINDLE Sea Fox - Mariah Talk 1 06-04-2010 02:02 PM
    Need help with hull ID mjhinno Introductions 9 10-05-2009 10:31 PM
    Thru-hull conversion. doofusmarine Original Mariah Talk 1 08-01-2009 12:10 AM
    There are 306 users
