drive unit u-joint rust?
Old 03-16-2018, 11:37 AM   #21
Hudson River Steve's Avatar
My Model: Z280
My Engine: 7.4L MPI Bravo3
Send Hudson River Steve:
Default Re: drive unit u-joint rust?
Originally Posted by sabujoseph View Post
hi
i have removed out drive alpha one of 1993 mariah inboard boat for replacing gimbal bearing and seal assembly,boots etc.
removed old bearing and put back new bearing
do i need any special tool to align spline shaft to bore.
i need advice on it. any link to see that please.
thanks
As long as you seated the new gimbal bearing properly there should be no need for further alignment. It is pretty straight forward.
Hudson River Steve
1999 Z280
7.4 MPI, Bravo3
    Removing Surface Rust ColoradoDiablo General Maintenance 1 02-15-2012 10:51 AM
    Gimbal bearing or U-joint unlikeno1 Mercury MerCruiser 5 05-27-2010 08:00 PM
    Rust in the coolant water. jetscat7 Original Mariah Talk 2 04-27-2010 05:01 AM
    U joint? Z212NH Original Mariah Talk 4 07-17-2009 12:04 AM
    Total Threads: 13,324
    There are 433 users
