drive unit u-joint rust?
Old 02-05-2014, 09:21 PM   #11
Default Re: drive unit u-joint rust?
While you have got it apart you might as well replace things like the u-joint and the gimbal bearing. Better than pulling it apart again in a year or two to do the same thing....
  • Old 02-05-2014, 11:41 PM   #12
    Txtruckerpaul's Avatar
    My Model: Z240 talari
    My Engine: 7.4 bravo III
    Send Txtruckerpaul:
    Snapped a couple of more pics, looking into the rear of the gimbal housing. doesnt look to good to me, what do ya'll think. I did take her out on the water a few months back and heard no funny noises such as whining, clunking or anything bad like that, not even on the sharp turns or at different speeds
    Old 02-06-2014, 12:09 AM   #13
    That is a wreck waiting to happen Paul.
    Need to change out that bearing for sure in my opinion.
    Just a matter of time til it grenades!
    Change the boot too , you're already half way there.
    Old 02-06-2014, 12:18 AM   #14
    Send Txtruckerpaul:
    thats what i was afraid of, but wanted to get advice from someone thats been there. isnt it supposed to be clean in there? i would think so. Thanks Larry, for your help. hope to have this thing ready by spring. It'll have new upolstery, carpet, wiring, and a screwed up gimbal bearing. lol
    Old 02-06-2014, 12:30 AM   #15
    Yes , it definitely should be clean. A little grime is acceptable , along with a bit of grease from greasing the gimble bearing. Rust/corrosion is second only to water when it comes to bad things happening with anything having to do with bearings.
    You got time , as long as the wallet holds out for a bit longer.
    Old 02-06-2014, 12:39 AM   #16
    Send Txtruckerpaul:
    yes, the wallet is going to be barking pretty good after this project is done!
    Old 02-06-2014, 02:34 AM   #17
    Its always something! Thankfully it is a fairly easy fix! Better to find that stuff now than in the heat of the season.
    Txtruckerpaul likes this.
    Old 02-06-2014, 02:50 AM   #18
    Send Txtruckerpaul:
    This is true, motoxxx! Downtime in summertime is disappointing! Think I'll just have my boat shop install a new one. By the time I bought parts and bought the tools to do it, it would cost just a little less than having a mechanic do it that knows what he's doing
    Old 02-06-2014, 02:57 AM   #19
    That's not a bad idea to have a shop check it out. I wouldn't have tackled that stuff but my old man is a television repairman, he's got this ultimate set of tools!
    Old 03-16-2018, 03:15 AM   #20
    sabujoseph is currently offline
    My Model: 18 I/O
    My Engine: 175 hp
    Send sabujoseph:
    hi
    i have removed out drive alpha one of 1993 mariah inboard boat for replacing gimbal bearing and seal assembly,boots etc.
    removed old bearing and put back new bearing
    do i need any special tool to align spline shaft to bore.
    i need advice on it. any link to see that please.
    thanks
    smds likes this.
    Removing Surface Rust ColoradoDiablo General Maintenance 1 02-15-2012 10:51 AM
    Gimbal bearing or U-joint unlikeno1 Mercury MerCruiser 5 05-27-2010 08:00 PM
    Rust in the coolant water. jetscat7 Original Mariah Talk 2 04-27-2010 05:01 AM
    U joint? Z212NH Original Mariah Talk 4 07-17-2009 12:04 AM
    Total Threads: 13,324
    There are 433 users
