frozen block? nnaaahhhh! well? OCD
Old 02-01-2014, 05:44 PM   #11
Default Re: frozen block? nnaaahhhh! well? OCD
I had a close call last year. I bought my Shabah in AZ and brought it to Colo in February. I drain everything prior to storing it. In March I started working on a few things and noticed a freeze plug was showing unpainted brass... Turns out there was sand in the block and it didn't allow all the water to drain.
I ended up just tapping the plug back in. 40hrs on the block and no problems since....
  • Old 02-01-2014, 05:47 PM   #12
    Originally Posted by Paul F View Post
    If it makes you guys feel any better, it used to be this cold nearly every winter years ago.
    Frozen at 30 degrees is the same frozen at 10 below. It only matters to living creatures. Machinery in storage doesn't care.
    Yep, i do remember a few of these types of 'winters' years ago.... and i still dont like them.
    How do i Access the fuse block CSofbuckeyelake General Maintenance 7 08-04-2017 05:38 AM
    Fuse block BDQ Mercury MerCruiser 1 07-11-2012 12:20 AM
    Fuse Block BDQ Original Mariah Talk 7 06-25-2012 12:51 PM
    Cylinder block warrenpark65 Volvo Penta 0 05-28-2010 08:27 AM
    1998 Z210 Shabah with a frozen outdrive. msmith68 Original Mariah Talk 5 04-16-2010 06:53 PM
    Total Threads: 13,324
    There are 372 users
