Gelcoat Colors Needed
Old 10-01-2015, 05:30 PM   #11
impact1839 is currently offline
My Model: z244 Jubilee
Send impact1839:
Default Re: Gelcoat Colors Needed
Did you ever find the gelcoat for your Jubilee? I have the same one. Appreciate your help!!
  • Old 04-27-2017, 01:47 AM   #12
    Asample34 is currently offline
    My Model: Z210 Shaba
    My Engine: 5.8 alpha1
    Send Asample34:
    Hi could I give you my hin# for colors
    Old 04-29-2017, 04:15 PM   #13
    dcraw is currently offline
    My Model: 1999 Z252 Shabah 7.4L Bravo I
    Send dcraw:
    Chris,
    can you still access the build sheets. I need the gel coat colors. I will supply the id # if you still can get them for me.
    Thanks for any help.
    Dale Crawford
    99 z252Shabah
    Old 05-04-2017, 05:39 PM   #14
    chuse927 is currently offline
    My Model: 272z Barchetta
    My Engine: 7.4
    Send chuse927:
    Originally Posted by ShabahZ280 View Post
    Luke7575, It's not impossible to get the info off the Hull ID, as I have paper copies of the factory build sheets from Hull #1 up to Hull #21864, (with the exception of the #'s 18000-19000). The primary and secondary gelcoats are clearly indicated. I had repair done to mine through a sea ray dealer, I gave them the color name from the build sheet, and they ordered it from MiniCraft, and it was an exact match, you couldn't even tell where it had been repaired. However, it was below the waterline, so perhaps it wasn't as exposed to the elements as yours was.
    Tom, According to your HIN, the Primary hull gelcoat is "Ivory", and the secondary color is "Polo". Looking at MiniCraft's site, these are the numbers you'll need.
    1993-1999 DT634 IVORY/ MARIAH
    1994-2001 GT748 POLO GREEN/ MARIAH
    GT636 POLO GREEN/ MARIAH BOATS
    If I had to take a guess, I'd say it would be the GT636, as it's a lower number, which most likely signifies an earlier model, although you may want to check and see if they have samples, or could provide you with more info to match the Polo.
    Shabah I sent you my hin a week or so ago were you able to get the color from it? I sent message at the forum.
    Sent from my SM-N920V using Tapatalk
    1995 Talari 190 Upholstery Colors vtfheffler Original Mariah Talk 1 06-10-2013 01:08 AM
    1995 colors buchshot12000 Projects 1 08-15-2011 04:22 PM
    What do the colors mean in the Mariah crest? Buddy Original Mariah Talk 1 05-24-2011 08:34 PM
    Paint Colors RUGMAN1973 Introductions 4 07-18-2008 01:15 PM
    Total Members: 18,990
    Total Threads: 13,324
    There are 233 users
