Help
Old 07-26-2013, 05:37 PM   #1
gcarlson is currently offline
My Model: Shabah
Send gcarlson:
Default Help
Hello...
Do you know where the fuse is for my powered hatch?
Gary
  • Old 07-26-2013, 06:05 PM   #2
    Default Re: Help
    Kinda hard to tell without knowing what Shabah you have.
    Old 07-26-2013, 06:10 PM   #3
    My Model: Shabah
    Send gcarlson:
    Default Re: Help
    oops it is a 1998 Mariah 24' Shabah with a 7.4L Bravo III Open bow. Sorry I am asking this for my Grandpa
    Old 07-26-2013, 06:13 PM   #4
    Default Re: Help
    Seen the year just wasn't sure of the model.
    If one of the guys don't give you a holler right quick , I'll be back to you.
    BTW: Welcome to MOC!!
    Old 07-26-2013, 06:24 PM   #5
    Default Re: Help
    Look under the dash on starboard side(driver) , the fuse panel should be right there.
    Not sure if they are labeled , but you can use a test light if need be to verify the fuses are good. If all are good it has to be inline , but the wiring diags show it's under the dash from what I can tell.
    Hopefully that helps you out.
    Old 07-26-2013, 06:39 PM   #6
    My Model: Shabah
    Send gcarlson:
    Smile Re: Help
    Thanks for your help, Larry! We'll give it a try!
    Old 07-26-2013, 06:48 PM   #7
    Default Re: Help
    Make sure you check back with your findings.
    One of the guys with the Power Hatch system is bound to chime in shortly.
    Old 07-27-2013, 03:45 AM   #8
    Dozer's Avatar
    Dozer is currently offline
    My Model: Z202 shabah
    My Engine: 5.0 liter alpha 1
    Send Dozer:
    Default Help
    My 98 z202 has the breakers in that spot under the dash on the side wall. They are labeled.
    Old 07-27-2013, 03:19 PM   #9
    Default Re: Help
    I forgot they switched to breakers.
    My bad
    There are 253 users
