Replacing 4.3Lwith 5.7L
Old 07-19-2013, 04:15 AM   #1
Jruggeri is currently offline
My Model: Z200
My Engine: 4.7L
Send Jruggeri:
Default Replacing 4.3Lwith 5.7L
Is it possible to replace a V6 with a V8? If so, would the power increase be noticeable.
  • Old 07-19-2013, 04:51 AM   #2
    rainman55343 is currently offline
    My Year: 2003
    My Model: sx 19
    My Engine: 5.7 alpha 1
    Send rainman55343:
    Default Re: Replacing 4.3Lwith 5.7L
    U could but u would have to change lower unit and out drive. I went from a 5.0to a 5.7. If u go from a 4.3 u should notice decent hole shot and top speed increase.
    Old 07-19-2013, 03:52 PM   #3
    Hello and welcome Jruggeri!
    To be perfectly honest , if you want a V8 then you need to buy you a boat with a V8.
    Unless you have deep pockets and lots of time , or absolutely love your boat now , it isn't worth the expense.
    Since you have a 200 , the weight issue isn't a problem , nor is the power rating of the boat.
    To do it right you're going to have either a load of money to invest in it , or you need a donor boat.
    JMO
    Once again ,
    Welcome!!
    Old 07-19-2013, 05:56 PM   #4
    yep.... you could have had a V8!
    Old 07-20-2013, 04:31 AM   #5
    phillycincykid's Avatar
    phillycincykid is currently offline
    My Year: 1990
    My Model: xlc 2150
    My Engine: 5.7 l mercruiser
    Send phillycincykid:
    after you spend all this extra money on gas your gonna be wishing that 4.3 back in. you can do anything you want but yes its a tremendous amount of work. buying a boat with av8 would be alot easier .
    Mariah 1990 XLC 2150 5.7 V8 about halfway rebuilt.
    Replacing interior joshandsony Original Mariah Talk 7 08-08-2012 12:53 AM
    Replacing Gauges douglas Original Mariah Talk 2 08-17-2011 04:46 PM
    Replacing Carpet newbie Original Mariah Talk 2 06-03-2011 07:10 PM
    replacing the belt littleray52 Mercury MerCruiser 2 08-13-2010 02:12 AM
    Replacing Bellows Paul Z General Maintenance 3 03-23-2010 04:43 PM
    There are 303 users
