runs a bit then dies
Old 08-10-2013, 12:11 AM   #11
usmckao is currently offline
My Model: 222 Z
My Engine: 5.7 Mercruiser
Send usmckao:
Default Re: runs a bit then dies
MECHANICAL FUEL PUMP!!!!!!
I think I have your fix. Had a 1987 Chaparral with an little 4 cylinder OMC that did the same thing, crank it driveway, run great on lake, but after it got good and warmed up it would bog down as if it's starving for fuel and eventually would die. Couldn't crank back up until the motor cooled off. Had numerous boat mechanics tell me it's either 1- anti siphon valve located near tank was sticking, 2- dirty carb, 3- spark plugs/wires.....they had no idea. I rebuilt carb---> no change. Did tune up to include plugs, wires, distributor cap and plug---> no change. Anti-siphon valve was clean---> no change.
It was the fuel pump. OMC motor had a mechanical fuel pump and when it got to operating temps, sludge inside would cause a blockage of fuel to carb. Replaced fuel pump with ease and boat ran like a champ!!!
  • Old 08-10-2013, 01:24 AM   #12
    His boat has electric fuel pump.
    Old 08-10-2013, 03:16 PM   #13
    uselessgrant is currently offline
    My Model: z1900
    My Engine: 4.3 omc cobra
    Send uselessgrant:
    I've been thinking about fuel pump, however my new ignition made huge improvement.but now it will stall sometimes when at wot trying to plane out. Holeshot is awful also.
    Engine Runs Great, I turn it off, can't get it restarted Chris Finch Mercury MerCruiser 5 09-07-2011 09:04 PM
    Proof it runs?? Caspersa21 Mariah Boats For Sale & Wanted 7 12-05-2009 12:03 AM
    There are 317 users
