rain water thriugh air intakes
Old 06-15-2013, 12:30 PM   #1
Lewy is currently offline
My Model: 182
My Engine: 4.3L mercriuser
Send Lewy:
Default rain water thriugh air intakes
Hi,
I bought a 182 recently which I haven't launched yet. however I have just noticed a design fault with the stern engine compartment air intakes. Rain water is running down the cover and the air intakes are directly in the path of the water. It doesn't take long for the bilge to become quite full.
(not in the UK anyway)
I guess the obvious option would be to extend the boat cover with 2 additional letter box size flaps which would cover the vents.
just wondering if anyone had any other simpler solution?
cheers
Lewy
  • Old 06-15-2013, 12:58 PM   #2
    csterner's Avatar
    csterner is currently offline
    My Model: Z275ST Shabah
    My Engine: 6.2L Bravo III
    Gallery Images: 9
    Send csterner:
    Default Re: rain water thriugh air intakes
    I would say 2 things, 1 would be to keep your drain plug out when it is on your trailer. If yours is slip kept, then I would buy 2 bilge pumps and 2 batteries!
    Also, if kept on a trailer, make sure that the tongue is raised so the water will flow aft and out your boat.
    2001 Shabah Z275 ST
    6.2L Merc with Bravo III
    Old 06-15-2013, 01:09 PM   #3
    I suspect it was a "whoever designed/installed the cover" fault rather than a boat design fault. My cover goes over the vents. And one of those 'intakes' is an exhaust outlet (or should be) for your bilge blower.
    Old 06-15-2013, 02:04 PM   #4
    My Model: 182
    Send Lewy:
    your right, it is a new replacement cover, however the company that provided the new one simply used the existing factory fitted poppers.
    Old 06-15-2013, 02:50 PM   #5
    Andy b's Avatar
    Andy b is currently offline
    My Model: Diablo 180
    Gallery Images: 9
    Send Andy b:
    Are there no back boxes on the vents?
    Old 06-15-2013, 03:54 PM   #6
    SEMIJim's Avatar
    SEMIJim is currently offline
    My Model: 182 Barchetta
    Send SEMIJim:
    Our custom-made mooring cover does not cover those, either. And, sure enough, when last summer we left the boat stored with the mooring covers on, instead of the trailing cover (the mooring cover is easier), we ended-up with a bilge-full of water.
    Oh well, at least I was finally motivated to clean the bilge
    Duct tape?
    Jim
    “The bitterness of poor quality is remembered long after the sweetness of low price has faded from memory.” - Aldo Gucci
    Click Here --> Help Support The Mariah Owner's Club <-- Click Here!
    Old 06-16-2013, 06:46 PM   #7
    nglauer's Avatar
    nglauer is currently offline
    My Model: 180 Diablo
    My Engine: 3.0L Alpha one
    Send nglauer:
    I've never paid attention to my buddy's 180 Diablo - but he keeps his stored at the local boat club all summer.. he has had to replace his battery a few times. I bet his cover is allowing the bilge to fill up - thus killing his battery from all the running it does. I will have to talk to him and see if that could be the problem because he's been concerned that something in the boat is sucking his battery dead, or shorting them out.
    Nick
    Old 06-16-2013, 08:17 PM   #8
    My Model: 182
    Send Lewy:
    Hi Andy, yes there are back boxes behind the vents which of course are there to stop water getting in, but as you know they have round cut out sections in the top portion of the box. 3 of these are 50% blanked off in the lower section of the hole with the top opening allowing air in and out. The other opening is for the blower and has the ducting poking through the hole.
    I just feel the slight downward angle of the box means that heavy rain fall will quickly fill the box allowing water in to the boat over the top of the half blanked off openings or even down the blower ducting.
    i'm going to re-mastic the sections to see if that makes any difference.
    Lewy
    Old 06-16-2013, 08:51 PM   #9
    Andy b's Avatar
    Gallery Images: 9
    Send Andy b:
    I didn't notice you are also in the UK
    for a quick fix you could do what I've done.
    but like I've said I have a Cheap £60 eBay cover that goes over the lot
    Thank you Andy b for this useful post!
    Lewy (06-17-2013)
    Old 07-06-2020, 01:59 PM   #10
    mmendenhall is currently offline
    My Model: Shabah 202
    My Engine: 5.0 MerCruiser
    Send mmendenhall:
    I know I'm bringing this back from the dead but would you still happen to have these pictures?
    I have the same issue with my 98 202. I finally got a slip at our boat club and sprung for a new snap cover. It also used the snaps that were already in place and it doesn't cover the rear vents.
    Luckily it's on a lift and covered fairly well from the elements but occasionally if the rain comes in just right, it will get into the vents.
    4.3 LX Water in oil jb57 Mercury MerCruiser 19 09-23-2013 12:35 AM
    First Water Run!! truckingeorgia79 Original Mariah Talk 9 02-20-2012 08:07 PM
    Rain, rain go away ..... 180diablo Chit Chat/Off-Topic 12 06-13-2008 12:37 AM
    how much water do you take on? bpfirrman General Maintenance 7 04-29-2008 09:35 PM
    Of Covers And Rain DrMatthewDunn Original Mariah Talk 6 04-24-2008 04:29 PM
    There are 477 users
