-   -   1994 350 mercruiser in a 22.5 foot mariah (http://www.mariahownersclub.com/forum/original-mariah-talk/8182-1994-350-mercruiser-22-5-foot-mariah.html)
stang1945 05-30-2013 02:11 PM
got this boat for some work i did someone had stole the outdrive.found one to replace it.looking the motor over it has a 4 bbl.just to the back of the carb there are some loose wires looks like something was bolted to the top of intake manifold.not sure what it was any help would be appericated. thanks jranes
ColoradoDiablo 05-30-2013 03:54 PM
Re: 1994 350 mercruiser in a 22.5 foot mariah
What colors are the wires stang?
BTW: Welcome to MOC!! :)
stang1945 06-01-2013 12:22 AM
1994 350 mercruiser tqlari 210
engine is a 350 magnum,has a 4 bbl carb.just behind the carb there are some loose wires.trying to figure out what they where hooked too.you can see 2 bolts in the intake where something was bolted.any suggestions,thanks jim
ColoradoDiablo 06-01-2013 02:44 PM
Re: 1994 350 mercruiser tqlari 210
As I asked in your other post on the same subject............What colors are the wires?:rolleyes:
stang1945 06-01-2013 06:28 PM
sorry did not see that post will check and get back to you. thanks jim
stang1945 06-03-2013 07:27 PM
blk
yel/rd
blk
red/purple
yel/red
this is wires thanks jim
ColoradoDiablo 06-03-2013 08:34 PM
Sounds like some of the "Starting System" wiring.
The best thing to do is look in the mercruiser manual. There is a complete color coded wiring harness section there.
Contributing members have access to these manuals and much more. :)
Please check it out here if your interested.
You need to look at the diagrams to see how the system is wired and works.
Blacks are grounds
Yellow/Red goes to slave solenoid
Red/Purple goes to circuit breaker via junction block
I hope this helped.
nglauer 06-06-2013 04:14 AM
It's worth becoming a contributing member - I had no idea how much stuff we had loaded on the site! I was so happy to view the original brochures and other material. It made me wonder why I held out for so long.
Good luck on putting your boat together. Post some pictures.. I think we all love looking at projects etc.!
