fuel filler for talari 216
Old 05-27-2013, 09:59 AM   #1
limarian is currently offline
My Model: talari 216
My Engine: mercruiser 5l
Send limarian:
Default talari 216 fuel fill
Would anybody know the correct diameter of the pipe section of a fuel cap assembly. It's either 1.5'' or 2''.
i want to remove the old cap and its' integrated short pipe and fit a new filler cap assembly. THis has to fit into the rubber pipe below which leads to the tank. i need to be able to match up the pipe from the filler assembly with the rubber tube.
regards
  • Old 05-27-2013, 10:02 AM   #2
    Send limarian:
    Default fuel filler for talari 216
    looking for suitable s. steel or chrome replacement
    Old 05-27-2013, 12:00 PM   #3
    Default Re: fuel filler for talari 216
    Did you have a look thru our Original Parts & Vendors List?
    Old 05-27-2013, 06:38 PM   #4
    Send limarian:
    yes i did - boats and boating said the original attwood is no longer available and suggested Attwood Gas Fill, 1.5 Inch Stainless Neck, Flip Open Cap. this however is an angled assembly with a breather. i am pretty sure the existing one is straight down with no breather. its almost impossible to see and i will have
    to cut a large hole in the upvc to get my hands through to unsccrew - i believe it is secured with a jubilee clip. This must be one of the most awkward jobs as ideally one woud rempve the rear bench seat to give a bit more room to get at things Anyway, it doesn't answer the vexing 1.5'' or 2'' questiion.
    Old 05-28-2013, 12:31 AM   #5
    We've had a few people inquire about replacing fuel caps so i'll have a look around the site to see if anyone has located a non-vented cap. In the meantime, my tape measure says 1.5"
    added info: I think i gave you this one back in Aug 2012 - Attwood "Indy style" SS 1.5 fuel cap
    there is also these from: Dana Marine
    limarian (05-28-2013)
    Jubilee 244 bow filler cushions dpriebe Original Mariah Talk 15 07-23-2014 05:34 AM
    talari 216 fuel fill limarian Original Mariah Talk 0 05-27-2013 09:59 AM
    fuel leaking @ filler cap??? tmk126 Original Mariah Talk 26 04-18-2013 05:00 PM
    Bow filler cushion Brad97 Original Mariah Talk 8 11-02-2012 04:08 AM
    fuel filler assembly for Talari limarian Original Mariah Talk 2 08-24-2012 06:58 AM
    Total Members: 18,991
    Total Threads: 13,324
    There are 180 users
