engine shuts off when shifting into gear????
Old 05-10-2013, 12:09 AM   #11
voodoo's Avatar
voodoo is currently offline
My Model: Davanti
My Engine: 5.7
Send voodoo:
Default Re: engine shuts off when shifting into gear????
Did an outdrive refit last year and should have done the cable.
Once back together it would stall on shifting.
I tried adjusting the switch, no go.
Pulled drive, again, put in a new cable.
Problem gone.
My understanding is the switch momentarily cuts the spark, allowing a smooth shift.
If the shift is not exact the spark cut is too long and the engine stalls. Docking and putting it back on the trailer became very frustrating to say the least.
If you are pulling the drive, I recommend new boots and a water pump since you're half way there anyway and the boat is 18 years old........
  • Old 05-22-2013, 02:21 AM   #12
    kjdevrou is currently offline
    My Model: z202 shabah
    My Engine: 5.0L alpha one
    Send kjdevrou:
    just got the boat back from the shop. the replaced the shift cable and also did the gimble bearing.
    problem fixed!!!!
    thanks to all for the advise.
    1995 Mariah Shabah Z202 5.0l alpha one
    Old 05-22-2013, 03:18 AM   #13
    problem fixed!!!!
    Congrats!
    engine just revs when in gear zzzino1 Mercury MerCruiser 7 09-16-2012 11:06 PM
    2000 Mercruiser 4.3 Alpha In Gear = Bumping from behind engine guyjusthere Mercury MerCruiser 6 06-29-2012 12:55 PM
    Shifting MariahCharlotte Mercury MerCruiser 1 06-01-2011 05:32 PM
    Control arm not shifting out of forward Lunaticutah Original Mariah Talk 3 06-26-2009 04:14 PM
    question about shifting 180diablo Mercury MerCruiser 0 07-24-2007 09:58 PM
    There are 374 users
