-   -   214 Jubilee - what in the hull (http://www.mariahownersclub.com/forum/original-mariah-talk/7997-214-jubilee-what-hull.html)
mikeyt 04-24-2013 06:11 PM
Re: 214 Jubilee - what in the hull
There you go. No lack of things to check out. Just make sure you let us know what you find! :yes_grin:
Oregondunes 04-24-2013 06:21 PM
Originally Posted by Douglas Alderman (Post 43364)
Inspect the rubber bumper around tne whole hull of the boat and check if the seal hasn't been pulled off from age.Mine has come lose and while plowing thru water all day the hull will gatheingr water and at the boat ramp taking out the pulg I get 5 gallions of water running out.Put clear silicon on the edges to seal it. Mine is a 1999 214 Jubille:wink_thumbup:
5 gallons ? doesnt your bilge pump turn on ? Im lucky if I see 1/2 gal. I from time to time manually turn on the pump and once in a while it spits for a minute.
leonweiland 05-14-2013 12:13 AM
I have '97 Jubilee. The water in my boat came from one of the drain tubes which delivers water from the two drain sinks on both the right and left rear corners of the boat. Not only will the boat take on water in the event of rain, it will take on water anytime the two drain holes on the exterior of the boat come below the water surface on which you are operating the boat. The more water the boat takes on the lower it sinks into the water, the more water it will take on. I would check these two tubes. In addition it would seem you should check the reason the bilge pump didn't kick on. If the water level gets too high you will be replacing the starter on the engine as it becomes submerged.
You bought a great boat. I have had mine for 14 years. Very few problems. Good Luck and God Bless!!
