Re: 1996 200 Shabah
I will give it a shot! Thanks for all your help
Re: 1996 200 Shabah
This is enough to make the motor fire, even if it's just pre ignition. Then the gas exhausting after the bang is strong enough to start the draw of air and fuel for the motor to run. giving it 1/3 throttle again aids vapour flow by opening the butterfly. Cranking when cold isn't always enough of a vapour draw to start the engine! once it's running back the throttle off and let the choke warm the motor. or it could be something else :rolleyes: |
Re: 1996 200 Shabah
Andy, sounds resonable as it seems I have read somewhere about the accelorator pump possibly needing replaced in the carb.
Re: 1996 200 Shabah
Guys, any of you have your sundeck or whatever you call the cushioned pad above the engine recovered? Need to get mine done and want to make sure I'm not getting hosed on the price. Just curious about what the cost would be.
| All times are GMT. The time now is 10:30 PM. |
