Summers comming and more stereo questions!
Old 02-26-2008, 02:53 AM   #11
z275st's Avatar
z275st is currently offline
Gallery Images: 33
Send z275st:
Thanks for all the info,
Guess I will pay the extra up front for marine grade. Otherwise sounds like I would be paying more later. Definitely think the bazooka is the way for me! I hadn’t thought of that.
John
2001 Mariah Z275st
496HO Bravo1
  • Old 03-11-2008, 05:38 AM   #12
    dieselwiezil is currently offline
    My Model: 2000 Mariah 212 5.7V8 Mercruiser Alpha I 21p mirage plus 48-13702
    Send dieselwiezil:
    well all my stuff has arrived and now im contemplating where to install the 2 10" subs. I really cany bring myself to cutting holes under the rear bench. Does anyone have thier subs mounted under the spotter and capitans dash?
    2000 Mariah 212 Mercruiser 350
    2002 F150 Supercrew
    1996 F250 Diesel lots of power goodies.
    "Out of everything I have, I still prefer riding MARIAH"
    Old 03-11-2008, 01:25 PM   #13
    indykoch's Avatar
    indykoch is currently offline
    Send indykoch:
    I had this same dilemma. I also thought about installing under the consoles, but then I realized how difficult it would be to build a box around the sub. Eventually, I decided the easiest, most logical choice was the bench. Cutting the hole made me want to cry... I couldn't stop thinking of the "what if's" - what if I cut it too big, what if I don't like the sound, what will this do to resale, etc.
    I can now say it was one of the best improvements to the boat. I consistently have friends asking me to use my stereo instead of theirs because it sounds so much better. I also have women "fighting" over who gets to sit on the bench seat - well worth the price of cutting a hole!!!
    Ryan
    Previously - '99 Z212 Shabah
    350 Mag MPI
    Old 03-12-2008, 03:21 AM   #14
    Send dieselwiezil:
    Ryan, do you have aniy pictures of your setup?
    2002 F150 Supercrew
    Old 03-12-2008, 05:00 AM   #15
    indykoch's Avatar
    Send indykoch:
    I only have this one that I found on my phone. The boat's in storage for the next month still, but I can get more pics at that time if you remind me.
    This was taken before I found a grill for the sub, so it matches the others and is somewhat protected now.
    Ryan
    350 Mag MPI
    Old 03-12-2008, 03:34 PM   #16
    Paul F's Avatar
    Paul F is currently offline
    Gallery Images: 4
    Send Paul F:
    Just remember, the more "thump" in your stereo, the more "click" in your ignition switch after floating and listening to your tunes all afternoon!
    Old 03-12-2008, 04:45 PM   #17
    indykoch's Avatar
    Send indykoch:
    Isn't that the truth!!! I forced myself to run the 5.25's off the in-dash so I didn't need 2 amps (or one big honking mofo). Still sounds great in my opinion. Good thing about my amp... it will start cutting out if the voltage gets too low. A great reminder to start it up and let the batteries charge.
    I'm getting new batteries this spring because I think one was going bad anyway. I'm also considering one of those relays that charge both, but separate them between starting and component use.
    Ryan
    350 Mag MPI
    Old 03-12-2008, 06:24 PM   #18
    Send dieselwiezil:
    Isnt that the purpose of 2 batteries? Would adding a gell cell (capacitor) to the system to increase longevity of battery life.
    2002 F150 Supercrew
    Old 03-12-2008, 06:42 PM   #19
    Z275's Avatar
    Z275 is currently offline
    Gallery Images: 15
    Send Z275:
    A gel cell or AGM battery would be better as a dedicated battery for your electronics. Gel cells or AGM have the advantage of not being damaged when completely drained. Your standard flooded or wet batteries do not like full drain / charge cycles. It decreases their life every time you do that.
    I don't know what kind of charger you have but mixing different types of batteries can present a problem for some chargers so make sure you check into that.
    The other option is just to use a standard wet starting battery as your primary battery and then add a standard wet deep cycle battery for your 2nd and put them on a switch. Switch to battery 1 when starting and battery 2 when docked.
    If you only have 1 battery now, adding a second is the best upgrade you could possibly do. Nothing like worrying about being stranded in the middle of the lake somewhere.
    Jason
    2001 Mariah Z275 - 405hp 7.4GSi
    Old 03-12-2008, 06:58 PM   #20
    Hi indykoch,
    Here are two ARC's from West Marine (click on the model):
    1) SI 120A 12/24V ACR (This is the one I use)
    2) BatteryLink ACR
    Hi Z275, you right on about the batteries and if anyone is thinking of dual batteries, checkout this thread started by aquaknot back in January, Batterries. It has a lot of helpful information!
    New owner with questions turfguy99 Original Mariah Talk 3 05-05-2008 01:30 AM
    Winterizing questions - 2003 SX9 Grease Boating 101 8 01-25-2008 07:07 AM
    There are 341 users
