Odometer & Water temp PaddleWheel Questions
Old 10-19-2012, 10:34 PM   #1
atomikpup187 is currently offline
My Model: Shabah Z 210
My Engine: 5.7 LX
Send atomikpup187:
Default Odometer & Water temp PaddleWheel Questions
Do you know what models/years this was used on? It looks like that may have been on my transom at one point. All that's left is a cut wire, a bracket and a speedometer that doesn't function. I haven't pulled the speedometer yet to see what type it is as the boat is in storage.
  • Old 10-19-2012, 11:29 PM   #2
    Default Re: Odometer & Water temp PaddleWheel Questions
    Does your boat have a factory depth sounder installed in the dash?
    Your speedo runs from a port on the front of the outdrive. It's probably just clogged.
    atomikpup187 (10-20-2012)
    Old 10-20-2012, 12:07 AM   #3
    My Engine: 5.7 LX
    Send atomikpup187:
    Factory depth sounder yes. Alright good deal thank you very much, i'll do some troubleshooting on that then. Thank you very much.
    Old 10-20-2012, 12:15 AM   #4
    Try just unhooking tube from speedo and blowing out with light air pressure. The pickup hole is located at the front trailing edge of the lower unit.
    Some times a small piece of sludge sand or what have you gets in the hole.
    Larry
    Old 10-21-2012, 04:25 PM   #5
    Paul F's Avatar
    Paul F is currently offline
    Gallery Images: 4
    Send Paul F:
    Or in my case, a broken drill bit..........
    What water temp does your engine run at? Jeff Barnett Mercury MerCruiser 15 05-13-2018 01:46 AM
    Water Temp markkearns General Maintenance 11 04-27-2009 07:17 PM
    Water Temp and Air Temp Panel brettk Original Mariah Talk 4 02-20-2009 09:20 PM
    water temp clockwood Original Mariah Talk 2 01-21-2009 04:05 PM
    There are 228 users
