-   -   Sluggish boat (http://www.mariahownersclub.com/forum/original-mariah-talk/7286-sluggish-boat.html)
TAT 08-08-2012 10:22 PM
Sluggish boat
I have been enjoying my summer on the water with the boat. At times I wish it was bigger.
When I first took the boat out, I reached a speed of 52mph at 4700rpm. Lately, The boat will only top out at 48 mph 4600 rpm. Any suggesttions or reason for the drop in speed. I have not done anything to it other then, oil change and fuel filter change.
I have a 1995 Barchetta z192.
mikesnowman 08-08-2012 10:49 PM
Re: Sluggish boat
more load? innaccuracy of gauges?
TAT 08-08-2012 11:09 PM
Re: Sluggish boat
The load is roughly the same. I thought maybe fuel filter, but I changed that with no increase with speed. Its not that big of a deal to me, just curious.
Thanks for reply.
phillycincykid 08-08-2012 11:34 PM
Re: Sluggish boat
i had that problem last year in my 5.7 . i would get to about 35 mph and would drop. it was a problem with the carburetor. i believe it was a butterfly valve? inside the carb that not opening all the way. idk if your engine has a carb or if its injected but might be worth checking out if u do have a carburetor
TAT 08-08-2012 11:39 PM
Re: Sluggish boat
My boat has a carb. I was thinking maybe the carb, sometimes when I throttle down it will hesitate.
Thanks for reply.
phillycincykid 08-09-2012 12:03 AM
Re: Sluggish boat
your welcome! thats what were all here for
Paul F 08-09-2012 06:58 PM
Re: Sluggish boat
The outside air temperature affects performance. The hotter it is, the less performance you get.
The best performance I ever got out of my boat was a cool spring day when I was by myself on flat water.
