-   -   how to adjust the trim (http://www.mariahownersclub.com/forum/original-mariah-talk/7145-how-adjust-trim.html)
megawatt72 07-11-2012 01:21 PM
I am haveing a problem raising the drive unit all the way up it seems to go about half way withe quicksilver 3000 stick. it will raise all the way using the control on the transom. any suggestions or recommendations would be appreciated.
mikeyt 07-11-2012 01:26 PM
Re: how to adjust the trim
Ummm... unless i am missing something that's precisely how its supposed to work. The trim button on the throttle should only take it up part way while the trailer switch should lift it up completely for trailering.
megawatt72 07-11-2012 01:41 PM
Shouldnt the stick take it all the way up as well? Only going half way up doesnt make sense to me. Is a safety thing for the out drive?
chaddv 07-11-2012 02:16 PM
Exactly... it's a safety limit for the outdrive. The Mercruiser manual states that if you 'tilt' it up beyond the upper 'trim' limit to keep the rpm's under 1500.
Although only "half-way" up seems more limited than usual.
Take a look at this to see if your trim limit swich and/or sender is adjusted correctly:
Trim Limit
mikeyt 07-11-2012 04:47 PM
As Chaddy noted, that is a safety feature. The trim up button is wired thru the Trim Limit Switch on the outdrive and on thru a solenoid to the Trim motor so that you can't inadvertently trim the drive up too far while underway.
Oregondunes 07-11-2012 06:12 PM
is there not a "trailering" button on the dash that will take the drive all the way up as well ? my 302 has one.
Paul F 07-12-2012 04:15 AM
The tilt button on that control is just behind the throttle. It's a recessed button on the lower rear corner.
It's hard to see, so I can understand you not seeing it.
DCB_MINDED 07-12-2012 01:53 PM
My Trailer trim button is about a 1 inch square that is lower down on the throttle stick.
