Speedometer only working When motor is trimmed wide open
Old 04-02-2008, 04:31 AM   #1
Hi CameronBrian2120,
Here are a couple of pictures of our outdrive to help you locate the intake and tubing. Now this is a Bravo III but if you have the Alpha Gen II then they are fundamentally the same.
The pencil tip is stuck in the very small Speedometer intake hole. Another place to look for a possible problem is where indykoch was referring to, at the plastic connector for the outdrive to transom assembly tubing (we found ours disconnected when we bought her).
Here's a photo of the speedometer tubing and connector at the outdrive indykoch was saying to check. Yours should be a twist connector, make sure it's firmly coupled.
  • Old 07-04-2012, 10:52 AM   #2
    Dcchapman is currently offline
    My Year: 95
    My Model: 180 talari
    My Engine: 4.3L alpha I
    Send Dcchapman:
    Default Speedometer only working When motor is trimmed wide open
    My speedometer only works when I am running at speeds that acquire me to trim the motor but once I slow down enough to lower the motor the speedometer will get stuck and just shows what speed I was going before I trimmed the motor down Is this common. It's a 95 180 talari Mercrusier
    Old 07-04-2012, 01:03 PM   #3
    Default Re: Speedometer only working When motor is trimmed wide open
    What kind of transducer do you have? Thru hull or mounted on the transom? If its a thru hull it may have become loose in its mounting hole. If its a transom mount, try cleaning the crud from the bottom of the unit.
    Old 07-04-2012, 06:09 PM   #4
    My Year: 95
    Send Dcchapman:
    I believe it is on the transom because of it working when I trim the motor up but I am confused where it might be on the transom. Because I do not know what it looks like. Thank you for posting to me on it I will get a better look when it is out of water and try to see if I can clean it some how
    95, Mariah 180 talari alpha I
    Old 07-04-2012, 08:32 PM   #5
    boater10 is currently offline
    My Year: 1991
    My Model: MX 19
    My Engine: Yamaha 4.3 L Yamaha
    Send boater10:
    I have a Yamaha sterndrive and had a similar problem. The speedo tube connects to the sterndrive and the connection needs a small "O" ring to make the connection secure. Without the "O" ring the speerd only works erradically. I installed a new ring and everything works fine.
    Boater10
    Old 07-04-2012, 11:20 PM   #6
    Must be the heat. I completely misread that post & the issue with the speedo.
    I agree with Voodoo. It could be a cracked or missing o ring or a small split in the pickup tube. I would remove the tube from the back of the speedo and then using a small compressor, blow air backward thru the line while having someone look for leaks at the outdrive end. Mind you there should be air coming out of the outdrive speedo pickup hole when you do this.
    I've copied over an old post by WetWilly (see post #1 in this thread) just to show you where the tube runs and where the outdrive speedo hole is.
    Old 07-29-2019, 01:49 AM   #7
    JR1996mariah is currently offline
    My Model: shabah
    My Engine: 3.0
    Send JR1996mariah:
    where can I purchase the plastic connector?
    Old 08-16-2021, 05:16 PM   #8
    HarlesG is currently offline
    My Model: 18' not sure yet
    My Engine: Merc 6 Cyl
    Send HarlesG:
    imo - sounds like your tube is getting pinched when you use your trim
    Old 08-17-2021, 12:05 AM   #9
    I think they've likely figured that out by now. The thread is 9 yrs old....
    Old 08-17-2021, 01:29 AM   #10
    Send HarlesG:
    5.7l 350 Mag (carb) Wide open throttle Lowflyer Boating 101 8 03-24-2012 04:52 PM
    Speedometer DuAnne Boating 101 3 10-25-2011 01:50 AM
    Wide open throttle bog turtle Mercury MerCruiser 10 04-30-2011 10:10 PM
    Motor Won't Open Up ? TMRoper1669 Mercury MerCruiser 2 07-07-2010 01:11 AM
    Speedometer - hour TomasSE Sea Fox - Mariah Talk 4 03-17-2010 04:46 PM
    Total Threads: 13,324
    There are 485 users
