-   -   Shrunk mooring cover (http://www.mariahownersclub.com/forum/original-mariah-talk/7017-shrunk-mooring-cover.html)
Brewfixer 06-23-2012 05:33 AM
Re: Shrunk mooring cover
Originally Posted by mikeyt (Post 36899)
Maybe get it warm & wet, snap on as many as possible then add weights or stretch up from the inside.
I have both the original vinyl covers and I had a new set made out of sunbrella material. Both sets are a bear to put on if haven't used them in a while. But to Mikeyt's point... I just let mine sit out in the sun and then with regular use they will fit okay. For me it is only hard to snap in the beginning of the boating season.
Now the new set I had made, I requested 3 vents so I can place support poles in them. I can adjust the poles up or down depending on the tightness of the cover. Makes it a whole lot easier to put on every time.
Good luck
PlumLazy 06-25-2012 03:51 PM
As others have said, the key is to get it hot. Once you get it on there... Use it often.
guyjusthere 07-03-2012 03:43 PM
you have to stretch it using heat. I use a heat gun VERY CAREFULLY
Gill 06-18-2014 03:47 PM
Originally Posted by BDQ (Post 36885)
Any ideas how to stretch out a mooring cover?
Try Boat Canvas Snap Extenders Snap Extenders A fix for your shrunk boat cover
mikeyt 06-18-2014 03:48 PM
Originally Posted by Gill (Post 53310)
Gill, this thread is two years old.
ShabahZ280 06-18-2014 06:28 PM
He's just reviving a thread to push his product. Normally, I'd frown upon this, but I have purchased these from him about a year ago and use them on my Z280. I will say they're a good product that can help with a shrunken cover. :wink_thumbup:
doaclnr 06-18-2014 06:36 PM
Originally Posted by knightriderz (Post 36921)
The original cover that came with our 220 Talari was the heavy vinyl cover and was very tight to snap on!!! It was very tight fit on a moderately hot day and nearly impossible to snap in place on a cool day! Try leaving the cover sitting in hot sun for a few hours. If it is the vinyl type I think you will be surprised how much it may stretch.
Good Luck!!
My 272 had the same problem with bow and cockpit. I didn't use them just for this reason... Only used the mooring cover. :(
