Fuse Block
Can someone help me locate my fuse block? I have a 1994 Davanti 235.
Thanks |
Re: Fuse Block
No One? I was told there is a fuse block somewhere on the drivers side.
Help. Thanks |
Re: Fuse Block
Mine is up underneath the dash on the right side next to the hull.
Re: Fuse Block
I don't have a Devanti but mine is not visable until i take the Head lid cover off. Sorry can't help.
Re: Fuse Block
Thanks guys, I will check those two areas. I looked under the dash and didnt see anything, but will look closer now.
Re: Fuse Block
I have a '93 Shabah 198 and my fuse block is under the dash close to the hull like mikeyt's. It's kind of hard to see under there but it's there.
Re: Fuse Block
There are 2 blocks, one of mine had an issue with a connector. The wiring under there is a mess. |
Re: Fuse Block
Well after removing multiple panels and things I probably have no business removing, I found the fuse panel! On our 94 Z235 davanti it is behind the starboard side upper interior trim above the shift/throttle controls. All that is required to access the block is to lift straight up on the trim piece ( the same set up as the dividers in the engine compartment). I felt very foolish after discovering the method of access. Hopefully this will help someone else.
| All times are GMT. The time now is 03:28 PM. |
