Alarm on 222 Shabah
Old 06-11-2012, 02:38 AM   #1
dannny is currently offline
My Model: 222shabah
My Engine: 350 alpha one
Send dannny:
Default Alarm on 222 Shabah
I have an alarm going off right behind the throttle intermittently. Curious about what the alarm is. Water temp is 175, oil pressure is good, and nothing seems to be wrong. Thanks.
  • Old 06-11-2012, 03:28 PM   #2
    Default Re: Alarm on 222 Shabah
    The alarm system also monitors the gear lube level. Check that as well. If it's full, it could be a bad gear lube level sensor. I had to replace mine due to the same symptoms.
    Alarm florida22 General Maintenance 2 06-20-2010 01:05 PM
    2001 shabah engine audio alarm John Steffy Original Mariah Talk 2 05-13-2010 08:58 PM
    why is my alarm going off ? Wurknman Original Mariah Talk 6 06-19-2009 08:44 PM
    Alarm? jmo Mercury MerCruiser 3 09-09-2008 02:09 AM
    alarm Mark Original Mariah Talk 10 11-26-2007 05:49 PM
    There are 354 users
