Re: my Mariah sunk
Sorry to hear bit a common problem if you rent a slip... especially with out-drives...usually a bad I/O hose will rot or get chewed by a rodent.. battery runs low with bilge water in > water out and the boat won't float.. a little common sense, rsearch and patience and you should be back in action no problem
| All times are GMT. The time now is 02:21 PM. |
