engine flooding?
Old 05-07-2012, 10:13 PM   #1
martin182 is currently offline
My Model: 182 Shabah
My Engine: Mercruiser 4.3L alpha1
Send martin182:
Default engine flooding?
has this happened to you or can you tell me what happened to me?.. my girl and i were cruising thru the marina water ways in HB, CA. at a very low speed of about 5MPH.. when i attempted to speed up a tiny bit..the engine began to make sounds like it wanted to stall. so i lowered the throttle back down...i throttled back up and it did it over and over again. so i left it at a very low idle so as to make it back to our home port in the marina. when i got in the larger water ways i throttled up and down and found that it cleared and the engine reacted normally...does anyone know why it was choking up like that... i would like to add that i smelled un-burnt fuel coming out of the exhaust. oh and how do i stop that from happening again?
2000 182 Shabah
need more details i can write alot more
  • Old 05-07-2012, 10:53 PM   #2
    DCB_MINDED's Avatar
    My Model: Shabah 238
    My Engine: 5.7 Alpha1
    Send DCB_MINDED:
    Default Re: engine flooding?
    Carburated or EFI?
    '99 Mariah Shabah 238
    5.7 Thunderbolt w/Alpha1
    Old 05-08-2012, 12:56 PM   #3
    Send martin182:
    DCB...it is EFI.
    Old 05-08-2012, 10:01 PM   #4
    Send martin182:
    it is EFI
    Old 05-08-2012, 10:23 PM   #5
    DCB_MINDED's Avatar
    Send DCB_MINDED:
    I don't know a whole lot about EFI. Being that it did it at idle, and not at higher RPM, I would look into the timing advance. Sorry I cant help more.
    Thank you DCB_MINDED for this useful post!
    martin182 (05-08-2012)
    Old 05-09-2012, 01:11 AM   #6
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    I would start by cleaning the throttle body of any carbon build up by the throttle butterfly valve. If you have a ring of carbon in this area it will not allow air to flow properly past the butterfly while the ECM is adding additonal fuel...hence the smell of unburned fuel. Use a sensor safe cleaner and a soft cloth and tooth brush to make it hospital clean. Let us know if this works or not and we can move on from there.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Flooding/fuel in oil boarder1010 Boating 101 32 07-28-2009 09:42 AM
    There are 250 users
