Manual
Old 04-27-2012, 08:23 PM   #1
janderson725 is currently offline
My Model: 222 Shabah
My Engine: 350 hp with Bravo III
Send janderson725:
Default Manual
I'm looking for an owners manual for a 2000 Mariah 222. Any advice on where to find one? I notice a link on the forum to a private message board that mentions manuals. Can i get access to that?
  • Old 04-27-2012, 09:49 PM   #2
    DCB_MINDED's Avatar
    My Model: Shabah 238
    My Engine: 5.7 Alpha1
    Send DCB_MINDED:
    Default Re: Manual
    You need to become a contributing member. For a few dollars, you get all of the owners manuals, service manuals, other flyers/brochures....
    http://www.mariahownersclub.com/forum/payments.php
    There is the link to contribute. It helps fund the site.
    '99 Mariah Shabah 238
    5.7 Thunderbolt w/Alpha1
    Old 04-27-2012, 10:17 PM   #3
    Default Re: Manual
    And here is a link to the 'sticky' that answers the question about "where do i find a manual?"
    Old 05-01-2012, 12:58 PM   #4
    Send janderson725:
    Default Re: Manual
    Thanks! I'll sign up today. I'm having problems with the faria trim and rpm guages. Is it best to try and repair them, or just get new ones. The mechanic I went to said these guages are a common problem with Mariah boats.
    Old 05-01-2012, 03:19 PM   #5
    Default Re: Manual
    The gauges are very seldom a problem on these boats contrary to what the 'mechanic' stated. Usually the problem involves a poor electrical connection at the gauge or the trim sensor on the outdrive being faulty. You can attempt to adjust the trim sensor & if you want to try here is a link to a "How To". Replacing the trim sensor requires removing the outdrive so most people just learn to live with the problem. If you eliminate both of those problems and the gauge still does not work, then you have a faulty gauge which is actually warrantied for life by Faria.
    janderson725 (05-07-2012)
    Wanted: manual Patrick Carter Mariah Parts For Sale & Wanted 3 03-30-2009 02:14 PM
    Wanted: manual wrodvold Mariah Parts For Sale & Wanted 2 03-28-2009 08:52 PM
    Still looking for manual John or Alleson Original Mariah Talk 5 10-02-2008 10:50 PM
    Manual waynexax Original Mariah Talk 3 06-16-2008 03:04 PM
    need a manual badly! joywind Introductions 3 05-13-2008 04:58 AM
    There are 359 users
