Re: LED lights???
And yes you definitely need the pole light on while you are anchored out at night or underway. |
Re: LED lights???
Re: LED lights???
I just got off the phone with the guys at superbright. Very helpful. He said the courtesy lights are not the brightest, but I explained that is probably a good thing for the interior. As for the anchor light, I told him I needed a shorter light and he told me about a 15 LED light that is basically the same thing as the 19, but it doesn't use high intensity bulbs, but they are 1/4" shorter. I'm going to get that along with the 19 and see what happens. As for the pole light, he told me these are the way to go. Super bright. More expensive, but more better. Check it out. The 45 led is 1.7" tall and .7" wide. I'm going to take my pole light apart and see if it'll fit. 1142-x45-T: 45HP-LED BA15D Tower Bulb |
Re: LED lights???
I already replaced the bulb in my pole light with a LED that "looked like that one", but naturally I can't remember the number of the bulb...it's a really really really bright one though.
Instead of using the auto extending pole light that came with the boat (4 footer), I use one that is 6 foot long so that it puts the light well above my line of sight if I look back at night. My pole light also has a deflector on it that directs the light outward and not down so it doesn't blind you at night. |
Re: LED lights???
Re: LED lights???
I too converted all my lights to LED including the console lights. The console lights were the trickiest because you have to be double jointed to reach up behind the console but the bleeding knuckles paid off:D. I also added LED's to all the cup holders and inside my speakers. Makes night time cruising very cool.
In about 2 weeks I will be mounting underwater LED's i purchased yesterday in the transom area. The one caution that i will tell you is that some (actually just one that I found) LED's do have a power bleed as i found on my anchor light. My 2001 Shabah Z222 came equipped with the telescoping anchor light and one night while putting the boat away for the evening i noticed the light was dimly lit. If you have a battery switch and use it religiously, it should not be an issue. But if you dont, it will drain the battery fairly quick. |
Re: LED lights???
Got the LED lights installed. The 15 LED light fits perfectly in the transom light, no modification necessary. And the tall tower LED worked great for the anchor light.
Brewfixer, you're positive it's the LED lights that cause the power draw? I don't see how that's possible because no power is provided to the lights when the switch is off. Using the battery switch is still probably a good idea. I need to upgrade to dual batteries soon. http://img.photobucket.com/albums/v1...-54-38_887.jpg http://img.photobucket.com/albums/v1...-11-30_722.jpg http://img.photobucket.com/albums/v1...-11-38_974.jpg |
Re: LED lights???
Re: LED lights???
I also wanted to add that superbrightled got my lights to me VERY quick. I placed the order on Friday and they were here on Monday. Doesn't get much better than that.
Re: LED lights???
Well anything is possible but when I put a meter across the switch I had nothing. However I did not do a continuity test to ground but you bet this weekend I will. |
| All times are GMT. The time now is 10:48 PM. |
