Power rear hatch.
Old 05-10-2012, 02:30 AM   #11
Brewfixer's Avatar
My Model: Z222
My Engine: 5.7
Send Brewfixer:
Default Re: Power rear hatch.
Originally Posted by ducker View Post
I just installed a flush mount table leg in the middle of the floor and just removed the 6 screws in the floor hinge of the benchseat and it pulled forward exposing the hatch and battery.easy fix.
Have you tried lifting the hatch by hand just a little and pull the bench seat forward? Works for me...
2001 Mariah Shabah Z222
  • Old 05-13-2012, 07:35 PM   #12
    cp55 is currently offline
    My Model: z220
    My Engine: 5.7 mag/ alpha 1
    Send cp55:
    I had some issues with mine also. I checked the connectors from the toggle switch all the way back to the lifts and found alot of corrosion on the grounds. I cleaned all these with a brush and battery terminal cleaner in a shot glass and drilled out the holes a bit on the hatch and bottom bracket to eliminate some binding. I also had my sundeck rehopolstered so I made a new plywood top with aluminum routed into it flush then tapped the holes so the brackets later wouldnt come loose. This made it quite a bit quicker (still not fast) and also dont have to worry later about the brackets. Hope this helps. Also thought about getting in with a dead battery or something I guess Ill have to lay the seat down and unload then pull the pins.
    Power engine cover/hatch NogginDoc Boating 101 1 07-19-2010 07:17 PM
    New Owner of z210 Talari...Power hatch oncman Original Mariah Talk 2 08-15-2009 09:28 PM
    Power hatch jasfiveo Original Mariah Talk 4 06-03-2009 02:22 PM
    Power engine hatch cover pics karmann Original Mariah Talk 0 05-09-2009 02:36 AM
    Power Seat And Hatch donbarb328 Original Mariah Talk 0 08-07-2008 08:58 PM
    There are 481 users
