Faria Instrument Gauges Do Not Light Up???
Old 04-23-2012, 07:21 PM   #1
smcomia's Avatar
smcomia is currently offline
My Model: Z272 Shabah
My Engine: Merc 454 Mag Bravo III
Send smcomia:
Default Faria Instrument Gauges Do Not Light Up???
I have a 1997 Z-272 Shabah with Faria gauges. The switch seems to be a dimmer type rotary switch. Ever since I bought the boat 5 years ago the gauges have not lit up. There is a very faint red back light that you can see but no matter what you do with the knob they do not change. It does not illuminate anything at all. At night I have to set my cell phone on the dash to see the speedometer & tach. There is light there and it is the same for all gauges so is it something to do with the switch?
Thanks in advance for any advice!
  • Old 04-23-2012, 10:50 PM   #2
    Default Re: Faria Instrument Gauges Do Not Light Up???
    Its a somewhat common problem with those dimmer/rotary switches and there is no direct replacement option that i'm aware of as Carling no longer makes that particular switch. Have a look at this thread where one of our members worked out a bypass solution.
    Old 04-23-2012, 11:01 PM   #3
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    If you don't care about dimming function...you can bypass the dimmer switch. Follow the wire from the lights switch that feeds the dimmer, disconnect this wire. Now find the wire that comes out of the dimmer and goes to all the lighting circuits on the various gages, disconnect this wire from the dimmer. Connect the two wires you just disconnected together and you should now have gage backlighting.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 04-23-2012, 11:14 PM   #4
    DCB_MINDED's Avatar
    My Model: Shabah 238
    My Engine: 5.7 Alpha1
    Send DCB_MINDED:
    Remember if you do this, your gauge lights will KILL your night vision. I need to hook mine to an accessory switch for just this reason.
    '99 Mariah Shabah 238
    5.7 Thunderbolt w/Alpha1
    Old 04-24-2012, 02:01 AM   #5
    smcomia's Avatar
    Send smcomia:
    Thanks everyone! I am new to this site and I have to say that I love it already! A lot of helpful insight.
    If it is just the dimmer switch, which is what I had suspected, can the dimmer switch just be replaced with a simple on/off switch? I found these switches, http://www.iboats.com/Marine-Works-R...-view_id.45144, in a post from Shabah z250 and was thinking that the 1-position on/off may do the trick???
    Old 04-24-2012, 02:22 AM   #6
    I dont see why not.
    Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
    For Sale: White Faria Gauges 64*thunderbolt Mariah Parts For Sale & Wanted 3 04-16-2011 09:29 PM
    For Sale: Complete set Faria/Mariah gauges mikeyt Mariah Parts For Sale & Wanted 1 04-10-2009 06:29 PM
    Question On Sx20 Faria Gauges AndyFL General Maintenance 3 08-13-2008 11:30 PM
    There are 363 users
