Alarm Sounding & Engine Dying???
Old 04-25-2012, 12:22 PM   #11
Hudson River Steve's Avatar
My Model: Z280
My Engine: 7.4L MPI Bravo3
Send Hudson River Steve:
Default Re: Alarm Sounding & Engine Dying???
As Dan suggests, you should get a manual for locations etc. You may want to ask a Merc Mechanic to come for a ride along with his scan tool plugged in, it will probably be worth the hour of his time. Hopefully the problem will occur while he is on board and he can locate the bad sensor or wire. It could be any of the things I already described or it could be other things like the MAP sensor wiring. It will take a process of elimination...nothing worse than an intermittent electrical problem. Happy Hunting.
TexasZ212 likes this.
Hudson River Steve
1999 Z280
7.4 MPI, Bravo3
  • Old 04-30-2012, 03:44 AM   #12
    DFZ272 is currently offline
    My Model: Z272 Barchetta
    My Engine: 7.4 Bravo III
    Send DFZ272:
    Scott, I just thought of something while working on my boat this weekend. There is an oil pressure safety shutoff switch which is seperate from the gauge sending unit. If u have a remote oil filter follow the lines down where they connect to the engine block. If you dont have a remote filter, the sensor should be next to the oil filter. The sensor should have one wire, probably tan and blue. On MPI this switch will also shut off the electric fuel pump. Just something else you can check.
    Happy Boating
    Dan
    1995 Z272 Barchetta
    2001 shabah engine audio alarm John Steffy Original Mariah Talk 2 05-13-2010 08:58 PM
    Alarm Sounding, but pressure/temperature look fine? aggressivebuggy Sea Fox - Mariah Talk 5 06-29-2009 04:59 AM
    why is my alarm going off ? Wurknman Original Mariah Talk 6 06-19-2009 08:44 PM
    Alarm? jmo Mercury MerCruiser 3 09-09-2008 02:09 AM
    7.4L MPI Engine Warning Alarm ShabahZ280 Mercury MerCruiser 13 02-09-2008 07:39 PM
    There are 459 users
