New Mariah Owner
Old 03-30-2012, 01:25 AM   #11
Hudson River Steve's Avatar
My Model: Z280
My Engine: 7.4L MPI Bravo3
Send Hudson River Steve:
Default Re: New Mariah Owner
Chris,
I had a couple of more thoughts from your previous thread. Have you double checked the multiple power and ground wires at the ECM connector? If it is missing any of these it could be the cause of your no start/fuel pump problems. Check that you have good solid grounds on J1-14 and J1-30 (black wires with white stripes). Check that you have solid battery voltage at J1-11 (pink/blk) with the key on and J1-16 and J1-32 (both Orange) key on or off.
MPI motors are great when they run but tough to troubleshoot when the don't.
Happy hunting.
Steve
Hudson River Steve
1999 Z280
7.4 MPI, Bravo3
  • Old 03-30-2012, 03:58 AM   #12
    Chris B is currently offline
    My Model: Z260 MCC
    Send Chris B:
    Hi Steve,
    Performed check on each socket on both J-1 and J-2. Every thing checked out except J-2-26. Manual does not indicate any voltage reading and with the J-2 unplugged from the ECM J-2-26 is carring 10 volts. J-2-26 is for the Audio warning buzzer and the buzzer does not sound when ignition switch is turn on. Did trouble shoot buzzer and it is good. Hopefully the Scan Tool will indicate a trouble code and lead to something and hopefully not the ECM.
    Chris B.
    1998 Z260 MCC
    7.4 MPI Bravo III
    Old 03-30-2012, 03:34 PM   #13
    Rick Emert is currently offline
    My Model: Z260 MCC
    My Engine: 7.4 Bravo III
    Send Rick Emert:
    Hi Chris, No I have not had any problems at all with the motor, replaced plugs wires and rotor last summer because I had a skip in it, found a plug wire had a hole burned in it but no problems at all.
    Dockwrecker
    Old 03-31-2012, 09:51 PM   #14
    Purple_Shabah's Avatar
    Purple_Shabah is currently offline
    My Model: Shabah 182
    My Engine: 4.3 Apha
    Gallery Images: 19
    Send Purple_Shabah:
    Nice looking boat!! Congrates!!
    Time flies when you're having rum.
    Old 04-02-2012, 12:58 AM   #15
    michaelreich is currently offline
    My Model: Barchetta
    My Engine: 4.3L LX V6 I/O
    Send michaelreich:
    My son just bought a 1993 180 Diablo - what a beautiful boat for it's age - I am quite impressed. We are getting it checked out, but it looks well taken care of. This is a great community you have here!
    Old 04-02-2012, 07:44 PM   #16
    DFZ272 is currently offline
    My Model: Z272 Barchetta
    Send DFZ272:
    Glad to know there is another member from South Louisiana on here. I frequent Lakes Maurepas and Ponchatrain. Send me a note if I can help with anything.
    Happy Boating
    Dan
    1995 Z272 Barchetta
    Old 04-07-2012, 06:12 PM   #17
    My Model: Z260 MCC
    Send Chris B:
    Hi Dan,
    I usually stay around Stevensville area and sometime toward the coast. Just got back from vacation today and Scan Tool came in. Hooked it up to the connector on the engine and it does not communicate with the ECM. It gives a check connection note. Checked all wires from the connector to the ECM and all check out. The grounds are grounded the power wires have power, the connections are good. I need to talk to someone who has experience with the Scan Tool. Maybe some one here has had experience with the Mercruiser Scan Tool, if so any info would be appriciated.
    Chris B.
    1998 Z260 MCC
    7.4 MPI Bravo III
    New Mariah owner Jgos929 Introductions 2 08-09-2011 02:36 AM
    New Mariah Owner - Need some help Baldeagle1 Introductions 2 06-08-2011 05:29 PM
    New Mariah Owner hootowlhollow Original Mariah Talk 2 04-08-2010 12:35 AM
    New Mariah owner Jonathan&Loren Introductions 5 04-06-2010 04:18 PM
    New Mariah owner Twkenny Introductions 2 07-28-2009 09:53 AM
    There are 318 users
