Dimmer Switch
Anybody know where I can buy a replacement dimmer switch for my Z280? I know it was made by Carlingswitch but cannot find any place to purchase a replacement.
Re: Dimmer Switch
Dont know what to tell you here Steve. When i did a site search on the dimmer switch i see a few other members with the same problem but no solutions. Perhaps you could contact Carling Technologies & ask them if they have something similar? They might require the part number off the existing dimmer though.
Re: Dimmer Switch
Do you need to just replace the switch or the actual dimmer module? They're two different parts, if I remember correctly. The module is something like this:
Digital Dimmers - Blue Sea Systems |
Re: Dimmer Switch
1 Attachment(s)
My dimmer is a single module, made of a printed circuit board attached to the back of a standard Carling Contura IV switch, see attached picture.
I have looked on the Carling website and they make a dimmer but it is an L series switch rather than a Contura IV and I do not think it will fit in my dash, not to mention that I cannot find any 12V versions of this LD series dimmer anywhere. http://www.carlingtech.com/pdf/CarlingCTRL_LD.pdf Perhaps Chris has the right idea, use the present Carling Contura IV switch, remove the printed circuit board and have it as an input to a separate dimmer module such as the the Blue Sea System. Thanks for confirming that I wasn't missing something simple. Steve |
| All times are GMT. The time now is 03:45 PM. |
