Grinding noise when first put in gear
Old 08-30-2011, 10:25 PM   #11
Mariahmaroo's Avatar
Mariahmaroo is currently offline
My Model: Z201 Talari
My Engine: 5.7L Merc Cruiser
Send Mariahmaroo:
Default Re: Grinding noise when first put in gear
I am pretty sure it us an alpha one gen two outdrive.
1996 Z201 Talari 5.7L
  • Old 09-06-2011, 12:33 PM   #12
    Send Mariahmaroo:
    Originally Posted by Shabah 198SE View Post
    Mariahmaroo,
    Sometimes people try this as a means of not replacing a defective rear shift cable. It is not a good solution.
    Shabah 198SE
    What are the possible consequences of adjusting the shift cable as apposed to replacing it? I don't want to replace it until the end of the season because that would just mean less time on the water for me. But I also have a big trip planned to go to Lake Powell (look it up, it is beautiful) and don't want any major problems.
    When I replace the shift cable I also plan to replace the Gimbal bearing, U-joints, and gears if needed, not to mention the bellows.
    Old 09-08-2011, 02:36 PM   #13
    Send Mariahmaroo:
    Anybody?
    4.3L Alpha 1 Noise in Idle from Reverse? Slash9point5 Mercury MerCruiser 9 04-17-2012 04:20 PM
    Grinding when turning?! mike699 Original Mariah Talk 7 09-07-2011 08:51 PM
    alpha one noise mwads275 Introductions 5 09-24-2010 12:53 PM
    Beeping Noise??? llcelebrity Original Mariah Talk 3 08-13-2009 04:34 AM
    Will grinding the first 3" of the trim cylinder piston rods hurt anything? bblauvelt Original Mariah Talk 6 03-18-2008 11:04 AM
    Total Members: 18,994
    Total Threads: 13,325
    There are 412 users
