Grinding when turning?!
About a month ago I started to hear a grinding coming from somewhere back by the engine. It was always the worst when I was turned hard left or right. I read some things and concluded it was the gimbal bearing. So I decided to tackle the bearing along with some other things myself. Here is a list of what I replaced and fixed.
-Gimbal bearing -All 3 bellows -trim sender and limit switch -anode kit -water pump -aligned engine -new gear lube -cooling hose I started the boat tonight on land after working on it all week after work and it sounded fine when I turned left and right in gear but then I got it into the water only to hear the same thing from before. The grinding occurs only when in gear and gets worse as your increase the throttle. It does the same thing in reverse as forward. When idling there is no grinding at any steering position. I think this points to something in the lower gearset because it doesnt happen when idling. Please help... I'm running out of patience and funds with this thing. :mad: Oh I have a 1993 Talari 200Z with 5.0LX alpha one gen 2. Thanks, Mike |
Re: Grinding when turning?!
mike699,
Sounds like u-joints. Shabah 198SE |
When I had it apart I checked for play in the ujoints. There didn't seem to be any issue there. Coukd they make noise without noticeable play? Also, they looked to be ungreasable. The grease zerks had plugs in them??
mike699,
It is pretty hard to check the u-joints with the lower unit off unless they feel rough when you move them. The only way to really check them is to remove them and take them appart. Once you've done that, you might as well change them anyway. On tight turns, these u-joint are under a lot of load. If your boat is a 1993 and they have never been changed, they are over due. I'm old school and if you change the u-joints, I recommend trying to find greasable joints and make sure that you install them with the grease fittings lined up. Shabah 198SE |
Well I changed the U-joints which was probably the easiest thing I did during the rebuild and no more grinding when turning!! Thanks for the advice! Hopefully get another few weeks of boating here in iowa.
Great news, enjoy the rest of your boating season. Shabah 198SE |
| All times are GMT. The time now is 07:53 PM. |
