Help me Identify this part
Old 07-21-2011, 08:38 AM   #11
Cliff_Haskins is currently offline
Send Cliff_Haskins:
Default Re: Help me Identify this part
Did you check behind the battery switch for fuseholders?
  • Old 07-21-2011, 02:59 PM   #12
    Mbaumy is currently offline
    My Model: 268 MCC
    My Engine: 5.7L, Bravo III
    Send Mbaumy:
    Yes I did, all ok. Have power to the out of the switch past the fuses but no power to the circuit breakers. I feel like there's a junction block I can't see. Found the large wiring harness in the cabin and only have power to known working circuits. Can't see where the harness comes from disappears behind cabin wall.
    Old 07-21-2011, 04:33 PM   #13
    Send Cliff_Haskins:
    Wires on isolator are not backwards? (Think of it as a large diode). If two crank batteries, there should be three wires... one in, two out. Also, what size boat, guess I missed that somewhere. Deep cycles usually run cabin power. As for the problem at hand - could be a bad ground, pin pushed out, chopped harness, etc..
    Old 07-24-2011, 03:15 AM   #14
    180diablo's Avatar
    My Model: 1993 Diablo 180
    Gallery Images: 30
    Send 180diablo:
    Hmmm, then what lies before that circuit breaker in question?
    Honestly, I can't see why the boat designers would bury a junction block where it wasn't easily accessible. As Cliff mentioned above, it could be just a bad wire.... somewhere.
    ~ Ryan
    Owner of the 3.0L Powerhouse!
    Can you identify? Maddog Introductions 6 08-15-2010 02:27 AM
    Windshield part number sweetdreams Original Mariah Talk 0 12-01-2009 05:48 AM
    Looking for rear part of bimini top urim Original Mariah Talk 1 05-27-2009 05:34 AM
    How do I identify the cylinder numbers on a 5.7 EFI? DGR-Z246-98 Original Mariah Talk 2 04-30-2009 12:05 PM
    Can someone ID this part? Z 202 Original Mariah Talk 10 07-03-2008 02:37 PM
    There are 234 users
