Re: Loading pics
Yeah she goes in next week for the brakes and brearings I told the guy I want them replaced so they are all the same as two have been replaced the others look original still as for the brakes never had anything to do with surge brakes before so I will let a pro handle them this time but thinking of getting a new trailer built with electric discs. Got a quote from loadmaster for 5200 add shipping with electric discs only a double axle trailer they said it is rated for almost 11000lbs so should be ok. Just debating on if I should go goose neck or regular.
Re: Loading pics
Surge brakes are pretty simple. Just a master cylinder with a piston. But I did have electric brakes on our old 28' cruiser that we had, and they worked great. Sometimes though the electric brakes will lock when you try to go in reverse. I still would prefer electric though. My big Wellcraft cruiser was a tandem axle and it handled well, but I tell you, after having a triple axle now on our Mariah, I would go triple. Especially if you do a decent amount of road time with your boat. The triples handle much better than the dual on the road. No sway at all on the highway. I have semis blow by me on the freeway and I never even notice it. And also, I can turn pretty sharp with it as well.
11,000 lb capacity doesn't seem right to me. From my experience axles either come in 3,500 lb or 5,500 lb capacity. So with a dual axle trailer and 5,500 lb axles, you theoretically have 11,000 lbs. But then you have to minus out the weight of the axles and trailer. And then that will give you the MAX weight. I would suggest staying below 80% of your max weight load. My preference is triple because of no sway on the road and if I ever blow a tire, I will have less chance of losing control! |
Re: Loading pics
Re: Loading pics
Good point I had only singles on my last 20' speeder and I had done so much to reduce wieght on the boat it wasn't funny shaved offer like 500+ lbs in the engine. I wonder how much it would be to switch this trailer to electrics and blast it and then I can repaint it too.
Re: Loading pics
Thanks Shabah I feel even better now. :) He shoots he scores!
Re: Loading pics
Re: Loading pics
Nice! The only way I would replace that trailer would be if I boated in salt. These trailers are very well made. Give it a little TLC if needed and spend your money on other things.
Re: Loading pics
the whole interior is not buckskin just the accent sections and wave stripes on the sundeck, oh and the cabin berth cushions with a lighter carpet will get some more pics this weekend as well as power polish on her check all fasteners, paint the fence, change the engine oil on her and the stang etc etc. Longweek end yeah sure more work at home then I do at work lol
| All times are GMT. The time now is 07:49 PM. |
