-   -   1995 Shabah 212Z Upgraded Vents (http://www.mariahownersclub.com/forum/original-mariah-talk/5729-1995-shabah-212z-upgraded-vents.html)
Mariah350 06-28-2011 12:58 AM
1995 Shabah 212 Z
Just wanted to show my upgrade of the original plastic bilge vents with the new SS vents. Had to fabricate two end pieces from stock aluminum and then pop rivet it to the new vents in order to secure to the boats existing screw locations.
I think it looks a bit better.
Here is a little info on the motor
I will post pics in a second or two.
Scat Rods 5.7 Pressed Pin forged
TRW L2256F + .030 Pistons Forged
Melling's M55Hv Oil Pump
Vortec 12558060 - SD8060A Heads
Comp Roller Tip cc1417-16 Rocker Arms
Comp Cams XM270HR Roller Cam
Hydraulic Roller Lifters
Cloyes True Roller timing set
Edelbrock 7516 RPM Air Gap
Crane Ignition HI-6M
Clevite Bearings
ARP Fasteners
GLM Aluminum Semi Tuned Exhaust Manifolds
Through Hull exhaust with Corsa exhaust tips
K&N Flame Arrestor
Powder Coated Stock Valve covers
Mariah350 06-28-2011 01:05 AM
Re: 1995 Shabah 212Z Upgraded Vents and Motor
2 Attachment(s)
Here are the images.
The first are the two of the vent upgrades and the second are for the motor described.
rajjneef 06-28-2011 01:34 AM
That's a nice 212 ya got there!
Zackattack 06-28-2011 05:38 AM
I second that!:wink_thumbup:
You should post a video on youtube of your engine running, I bet that thing is amazing.
Good job.
95gts 06-28-2011 12:06 PM
Wow, fantastic job! :wink_thumbup: Nice work on the engine details. That 270 cam should give a nice chunky idle too. :D
