Z210 Shabah Top Speed
Old 05-14-2019, 08:10 PM   #41
mustang67gt1's Avatar
mustang67gt1 is currently offline
My Model: 1996 Mariah
My Engine: 5.7
Gallery Images: 7
Send mustang67gt1:
Default Re: Z210 Shabah Top Speed
Since my post I have done quite a few things. Over the winter I pulled the motor and did a complete rebuild with Vortex heads and a roller factory style cam. the pistons I went to speedpro Hypereutectic at 9 1/2 compression. The intake is a aluminum intake made by Jegs for vortex heads. I installed a upgrade petronix ignition and coil with 9mm plug wires. The carb is a 650 Edelbrock marine and a carter electric marine fuel pump. I am still breaking the motor in and have not had it all out yet. Cruising at 4000 RPMS I am currently doing 49.6 mph. In a few weeks I will be able to do the full 5000 RPMs and should run close to 60mph. My other motor you talked about did a best of 54mph with 2 people. I have the same prop which pulls hard out of the hole and good top end. Its a SS 14 1/2 x 19 prop works very well.
I added some pics of the new motor and boat hope they go through.
  • Old 05-14-2019, 10:33 PM   #42
    Frostyz210 is currently offline
    My Model: Z210
    My Engine: 5.7 alpha 1
    Send Frostyz210:
    What make and model prop was it that you have
    Old 05-15-2019, 06:22 AM   #43
    My Engine: 5.7
    Gallery Images: 7
    Send mustang67gt1:
    I'm sorry the prop is a 15/21 prop, not the 14 1/2 19. The prop is a yamaha Salt series. I have been using this for a while now
    Old 06-27-2019, 11:04 PM   #44
    sandersbw is currently offline
    My Model: shabah 212
    Send sandersbw:
    1995 Shabah 212 with a 350 Mercruiser, On a fairly smooth day we top out around 46. Not sure on the prop though.
    Old 06-27-2019, 11:10 PM   #45
    My Model: Z210
    Send Frostyz210:
    I ended up buying a 21 pitch laser 2 and the boat now does 50 at 4800 before it would only do 45 at 5100 with a black max 14x19
    212 , shabah , speed , z210
    1996 Z210 Shabah new owner baker721 Introductions 7 06-21-2011 12:26 AM
    1998 Mariah Z210 Shabah Proud Owner mark43 Introductions 1 08-17-2010 07:56 AM
    1998 Z210 Shabah with a frozen outdrive. msmith68 Original Mariah Talk 5 04-16-2010 06:53 PM
    1997 Shabah Z210 Captain Steve Introductions 4 09-23-2007 06:22 PM
    There are 352 users
