Z210 Shabah Top Speed
Old 08-17-2011, 10:33 PM   #31
ual777mech's Avatar
ual777mech is currently offline
My Model: z210
My Engine: 7.4 bravo III
Send ual777mech:
Default Re: Z210 Shabah Top Speed
thanks it has a
7.4 454 engine
capt choice adds speed.
great and fun boat
  • Old 08-19-2011, 03:57 AM   #32
    mark43 is currently offline
    My Model: Z210 Shabah
    My Engine: 5.7L Bravo III
    Send mark43:
    Lightbulb Re: Z210 Shabah Top Speed
    Hi Everyone,
    Does anyone think it is weird that with a 250hp 5.7L and Bravo III in my Z210, I am only able to get 48mph with three adults in the boat? I would have thought I could get up to 52-55 mph with that set-up. My RPMs are right where they should be. Does this appear reasonable? If not, does anyone have any suggestions?
    Thanks!
    Old 08-19-2011, 12:01 PM   #33
    Mariah350's Avatar
    Mariah350 is currently offline
    Send Mariah350:
    Originally Posted by ual777mech View Post
    1996 mariah z210 limited edition
    7.4
    2 people smooth water 62mph.
    Just wondering if that speed is on the speedo or Gps?
    thx
    1995 Mariah Shabah 212 Z
    Performance Built 355 Vortec
    Alpha One Merc Laser II 21''
    GPS 64 Mph @ 5100 RPM
    Old 08-19-2011, 01:50 PM   #34
    Send mark43:
    It is on my GPS, so it should be spot on.
    Old 08-28-2011, 02:08 AM   #35
    jarwiebe's Avatar
    jarwiebe is currently offline
    My Engine: 5.7 LX Alpha I
    Gallery Images: 2
    Send jarwiebe:
    Just got home from a afternoon of boating.
    WOT of 4,800
    Boat speedo showed 52 (forgot my GPS at home)
    Equates to 11% slip if speedo is correct.
    Calculated speed if slip is 15% would be between 48 and 50 which sounds more right.
    1996 Z210 Shabah
    5.7LX MerCruiser
    Alpha 1 with 1.47 gears
    14 1/4 x 19 Aluminum Turning Point prop
    80 lb smart tabs set at middle setting
    3 adults
    3/4 tank of gas
    It seemed like I wasn't planning as high as I should be so maybe need to try a lighter setting on the tabs which might give me an extra mile or two on the top end.
    Cheers
    Jake
    1996 Z210 Shabah
    Mercruiser 5.7LX
    Alpha One Drive
    80 Lb. SX Smart Tabs
    Old 09-06-2011, 01:53 AM   #36
    jarwiebe's Avatar
    Gallery Images: 2
    Send jarwiebe:
    Just ran another test, 3 adults, 1/2 tank of gas, water smooth as glass.
    51 MPH GPS
    53 MPH on boat speedo
    4,700 RPM
    smart tabs set on the second hole from the lightest setting.
    Cheers
    Jake
    1996 Z210 Shabah
    Mercruiser 5.7LX
    Alpha One Drive
    Old 06-20-2012, 03:46 AM   #37
    Climateeast is currently offline
    My Model: Shabah Z222
    My Engine: 454 mpi mie mag
    Send Climateeast:
    I have a 98 shabah 454 mag mpi with bravo 3 and I'm running 70 gps. 26 pitch props that have been cupped
    Old 06-21-2012, 10:24 PM   #38
    PlumLazy's Avatar
    PlumLazy is currently offline
    My Model: 210
    My Engine: 5.7, Bravo III
    Send PlumLazy:
    Figured I'd chime in even though this is a fairly old thread.
    My very low hour '94 Shabah Z211 with stock 5.7 4-barrel and Bravo III and thru-hull exhst., and the stock quicksilver 24p props GPS'd at 57 mph in light chop. (speedo does not work) With over 10 gal of fuel and two skinny adults. lol. Top speed was with the trim 1/8 up on the guage.
    I just installed a K&N filter and am hoping with less fuel and just me it will go 60... just so I can say I did it once. lol. BTW... I lost track of the RPM when I was watching the GPS, but was a tick over 4500rpm I beleive. When we tested it before purchase with 3 adults and a full tank (30gal?) it GPS'd at 54mph.
    Bob
    Canyon Lake, TX
    '94 Shabah Z211, 5.7 Bravo III
    Old 03-19-2013, 07:39 AM   #39
    mustang67gt1's Avatar
    mustang67gt1 is currently offline
    My Model: 1996 Mariah
    My Engine: 5.7
    Gallery Images: 7
    Send mustang67gt1:
    My 1996 shabah Z210 with 5.7 runs 53-54 mph with wife, teenage daughter & boyfirend, 12 yr old daughter and friend. This is with the 2bl motor, electric marine fuel pump, K&N filter and aluminum prop. Next year I am changing over to an aluminum manifold, 4bl carb, Mallory pointless ditributor and hopefully will get to the 57-59mph....I have had this boat out once so far just purchased end of last year. Seems to have great power all the way through Owner called me a week later and try to purchase back? I bought for $7800 nice condition.
    Old 05-14-2019, 05:59 PM   #40
    Frostyz210 is currently offline
    My Model: Z210
    My Engine: 5.7 alpha 1
    Send Frostyz210:
    I know this is an old thread but what was it you were running for a prop? what did you end up going with? and what were the results? I have an identical setup but can only get it to run 45 on GPS by myself with the 3 blade aluminum prop on it that over revs to 5100 father in law just brought home a brand new cobalt and I want to try and out do the 52mph that will do thanks
    212 , shabah , speed , z210
    1996 Z210 Shabah new owner baker721 Introductions 7 06-21-2011 12:26 AM
    1998 Mariah Z210 Shabah Proud Owner mark43 Introductions 1 08-17-2010 07:56 AM
    1998 Z210 Shabah with a frozen outdrive. msmith68 Original Mariah Talk 5 04-16-2010 06:53 PM
    1997 Shabah Z210 Captain Steve Introductions 4 09-23-2007 06:22 PM
    There are 476 users
