-   -   Engine stalling problem (http://www.mariahownersclub.com/forum/original-mariah-talk/5626-engine-stalling-problem.html)
Zackattack 07-06-2011 04:23 PM
Re: Engine stalling problem
Did you try new fuel?
voodoo 07-06-2011 06:17 PM
Originally Posted by theeasynine (Post 30689)
I don't know really what to do about it. There is a fuel line that runs a little close to the block we might try re routing to see if that helps.
I think that line comes off of the diphragm and should not contain fuel.
If it contains fuel, it is because the fuel pump is faulty.
That line runs to the carb so that leaking fuel is directed to the carb, not the bilge.
