Anybody having trouble with their OE depth finder?
Old 06-20-2016, 09:10 PM   #21
CHICKS75's Avatar
CHICKS75 is currently offline
Status: I got this...
My Model: 210 Z L.E. SHABAH
My Engine: 5.7 Alpha-One Gen II
Gallery Images: 15
Send CHICKS75:
Default Re: Anybody having trouble with their OE depth finder?
That paddle wheel is for your tripodmeter/air/water temp. The in hull transducer, if that is what you have, is located under the engine, belt area, by the bilge pump towards the bow.
1998 Shabah 210Z L.E.
5.7L Alpha-One, Gen II
  • Old 06-21-2016, 06:57 PM   #22
    Here you go Heckman15, this is a pic of the engine bay from my old Z250. The black "hockey puck" you see in the middle of the floor slightly behind the engine mounts is the depth transducer.
    The Following 2 Users Say Thank You to ShabahZ280 For This Useful Post:
    Firestone (06-14-2017), Heckman15 (06-21-2016)
    Old 06-28-2016, 04:24 AM   #23
    pllevine's Avatar
    pllevine is currently offline
    My Model: 202 Shabah
    My Engine: 5.0L Alpha
    Send pllevine:
    Funny enough, but I just replaced my Lowrance 3500 with a Faria In-hull unit and it works great! I have a Humminbird Chartplotter running next to it and I have no cross-talk issues as they work on different frequencies.
    CHICKS75 and Firestone like this.
    Phil Levine
    1998 202 Shabah
    Old 06-28-2016, 01:20 PM   #24
    CHICKS75's Avatar
    Gallery Images: 15
    Send CHICKS75:
    pllevine
    I'm needing to do the exact same, i have some questions if you dont mind?
    1. Did you get the gold bezel?
    2. Do you have a part #?
    3. Any install tips?
    Thank you sir.
    Thank you CHICKS75 for this useful post!
    Firestone (06-29-2016)
    Old 06-28-2016, 01:23 PM   #25
    CHICKS75's Avatar
    Gallery Images: 15
    Send CHICKS75:
    Originally Posted by Heckman15 View Post
    I know this is an old thread, but does anyone have a picture of where their Transducer mounts? I am a new owner of a 2001 Z250 and the only thing I can find I assume is for my speedometer (which doesn't work) that has a black plastic wheel.
    Heckman,
    Regarding your speedo, have you looked into your outdrive to see if the hole os plugged up with debris?
    Old 06-28-2016, 06:28 PM   #26
    My Model: Z202
    Send Firestone:
    Mine just went on the fritz this last weekend. It is giving me multiple 3 digit codes after flashing several times. Thanks everyone for the input. I will start with the wires and go from there. I am also having issues with my tach jumping around, but I have not tired the selector trick on the back yet. Could it be that they both have a grounding issue?
    John
    Old 06-29-2016, 09:19 AM   #27
    pllevine's Avatar
    Send pllevine:
    Originally Posted by CHICKS75 View Post
    pllevine
    Thank you sir.
    Phil Levine
    1998 202 Shabah
    Old 06-29-2016, 09:41 AM   #28
    pllevine's Avatar
    Send pllevine:
    Unfortunately, Faria did not have an option for a gold-ringed gauge. I have heard of people taking the old Lowrance gauge, cutting off the ring, and gluing it over the silver Kronos gauge ring. It really wasn't that important to me yet. As long as my depth gauge was working flawlessly, I could deal with a silver bezel.
    Honestly, working below the engine's oil pan in the bilge with a Dremel tool was the hardest. I had to cut away a little more of the stock hole in the inner hull in order to mount the new transducer mount to the inside of the outer hull. Air mar makes the new transducers for Faria and you can adjust the deadrise on the transducer easily. I used a bead of 4200 around the flange of the new transducer mount where it meets the outer hull. It has to be a waterproof seal as the airspace between the outer hull and the new transducer is filled with propyl glycol (antifreeze). Then I used Bondo to seal the inner hull around the mount tube in order to keep the bilge water from running between the inner and outer hull, even though the stock Lowrance puck was not sealed and water flowed in between.
    After I finished with the In-Hull Airmar unit, I had to drill the transom and mount the unit for the Humminbird chartplotter.
    My speedometer hasn't work since I bought the boat, so I took a small drill bit and, using just my fingers, twisted the bit into the outdrive's speedo pitot hole and cleared out the years of corrosion and scale buildup. It worked like a charm. Now my speedometer is operational and matches the GPS speed on the chartplotter. All that I have left is the trim sender replacement (I am going through the transom again- no way am I going to screw with the bellows! If it's not leaking oil, why risk it?)......
    Phil Levine
    1998 202 Shabah
    The Following 2 Users Say Thank You to pllevine For This Useful Post:
    CHICKS75 (06-29-2016), Firestone (06-29-2016)
    Old 06-29-2016, 01:51 PM   #29
    CHICKS75's Avatar
    Gallery Images: 15
    Send CHICKS75:
    Thank you sir!
    Depth finder inop theeasynine Original Mariah Talk 24 09-06-2010 05:45 PM
    Depth finder woes NogginDoc Boating 101 1 07-19-2010 04:35 PM
    Depth Finder Problem?? hatran Introductions 2 05-20-2010 06:18 PM
    Depth Finder works the first minutes then mad ebb8827 Original Mariah Talk 8 03-23-2010 03:52 PM
    Depth finder joeboat Original Mariah Talk 1 08-21-2009 12:54 AM
    Total Members: 18,991
    Total Threads: 13,324
    There are 277 users
