Anybody having trouble with their OE depth finder?
Old 08-03-2011, 09:13 PM   #11
jarwiebe's Avatar
jarwiebe is currently offline
My Model: Z210 Shabah
My Engine: 5.7 LX Alpha I
Gallery Images: 2
Send jarwiebe:
Default Re: Anybody having trouble with their OE depth finder?
Thanks for that tip ShabahZ250, I'll try that as well.
Cheers
Jake
1996 Z210 Shabah
Mercruiser 5.7LX
Alpha One Drive
80 Lb. SX Smart Tabs
  • Old 08-08-2011, 01:26 AM   #12
    jarwiebe's Avatar
    Gallery Images: 2
    Send jarwiebe:
    Was out yesterday and today, and here is an update on my depth finder readings. I was running only the OEM depth finder this time, so no "crosstalk", no water in bilge and for most of the time it showed the correct depth. Intermittently though, it would start blink the last reading it had and after awhile (several minutes in most cases) it came back again with the correct readings. This happens when idling or on plane, there doesn't appear to be a pattern to when it happens. What I have not checked is connections at the digital display, so that is my next task. I am assuming I can get at them from behind the headrest in the bow section. This time I never got the 3 digit readings so I assume those must have come from the "crosstalk".
    Brian Belcher and Firestone like this.
    Cheers
    Jake
    1996 Z210 Shabah
    Mercruiser 5.7LX
    Alpha One Drive
    Old 08-08-2011, 01:47 AM   #13
    Slamsanders is currently offline
    My Model: 192 shabah
    My Engine: 5.0 alpha I
    Send Slamsanders:
    I don't know if your depth finder is like mine or not. I don't know what model mine is. But mine has a ring that is epoxyed to the hull inside the engine compartment and then the transducer locks in place onto that ring. And the air space between the two needs to be filled with mineral oil. I know mine was all over the place or didn't work at all until I did that. But yours may be totally different. Hope this helps.
    Old 08-08-2011, 01:34 PM   #14
    mosky's Avatar
    mosky is currently offline
    My Model: 202
    My Engine: 5.0L Alpha
    Send mosky:
    Don't know if this is common or not but mine was driving me crazy until i finally figured out my problem. Tried water in the bilge, re-epoxying the transducer and cleaning the contacts at the head end. Turned out that it was a bad connection where the lead actually goes into the transducer. Only found this after taking it off for the second time to re-epoxy the transducer back down. The wire right at the 'puck' must have been at ome point crimped or kinked (during engine installlation or maintenence perhaps) and it resulted in a connection that worked most of the time but would interrmittently start blinking the last reading or some large 3 digit depth. turning it off and on sometimes would seemingly 'cure' the problem but usually not for long. after many attempts at fixes i finally ordered a 'new' transducer off the internet and re-epoxied it in place and since then everything has been fine. The transducer only cost me about 20 bucks and before I removed the old transducer for the last time I hooked up the new transducer and tested it by hanging it over the side and everything was good. Only problem I experienced from there was trying to get a good air bubble free seal on mounting the transducer. i found with the 3M marine sealant it would work at first but after a day or so it would stop working. Ended up using epoxy and everything was fine. just have to make sure you get good contact with the hull and you don't get air bubbles in the epoxy both when you're mixing and when it cures.
    Old 08-16-2011, 11:52 PM   #15
    Purple_Shabah's Avatar
    Purple_Shabah is currently offline
    My Model: Shabah 182
    My Engine: 4.3 Apha
    Gallery Images: 19
    Send Purple_Shabah:
    Well, another weekend on the boat another adventure with the depth finder!! adding water to the bilge didn't seem to help, of course the automatic bilge pump took care of that:mad
    : anyway the depth finder seems to work great on plane or sitting still as long as your in water deeper than 6 feet, once you get in water shallower than that it go's to the lowest depth (like 6.8 feet) or so and then just blinks away at that last reading under 7 feet.
    Once you go back into water over 8 feet, it work just fine again!!! really really frustrating!!!!
    Time flies when you're having rum.
    Old 08-30-2011, 01:50 AM   #16
    jarwiebe's Avatar
    Gallery Images: 2
    Send jarwiebe:
    Well I finally exhausted my efforts at getting my depth finder to give me consistent readings and gave it a good yank and sure enough it came off. I could tell that it had not been properly seated and must have had an air space underneath it. I cleaned things up ( a PITA working under the 5.7) but got it cleaned and seated it in toilet bowl wax ring as per stereoman405 post #15 in the Aftermarket Depth Gauge thread. I am going out next weekend and will see whether the wax mounting trick works for me. I was going to try this before epoxy just to ensure the transducer itself is functioning ok and then make the decision about epoxy.
    Cheers
    Jake
    1996 Z210 Shabah
    Mercruiser 5.7LX
    Alpha One Drive
    Old 09-06-2011, 01:47 AM   #17
    jarwiebe's Avatar
    Gallery Images: 2
    Send jarwiebe:
    Back from our weekend and still have the same old problem. The depth finder will start flashing the last read depth on occasion and sometimes stays this way for a long time and at other times it comes back after several minutes or less. There is no consitancy. Setting the transduce in wax seems to have worked but there must be a malfunction in the transducer itself or in its wire. I guess my next try will be to try a different transducer.
    Cheers
    Jake
    1996 Z210 Shabah
    Mercruiser 5.7LX
    Alpha One Drive
    Old 05-15-2012, 02:53 AM   #18
    jarwiebe's Avatar
    Gallery Images: 2
    Send jarwiebe:
    Who would have guessed it, first time out this year and the depth finder functioned perfectly. I did nothing to correct the problem since my last post. The only difference was the water I was in. Last season the water we were in was fairly green with algae (small lake), yesterday we were in a fairly fast flowing river (the Red River), it is fairly brown but no algae. Could this be the difference?
    Cheers
    Jake
    1996 Z210 Shabah
    Mercruiser 5.7LX
    Alpha One Drive
    Old 09-29-2012, 09:18 PM   #19
    jarwiebe's Avatar
    Gallery Images: 2
    Send jarwiebe:
    Just a follow-up to these post, I have run all season (put on about 30 hours) and the depth finder has functioned flawlessly. So if anyone is wondering whether the toilet bowl wax works as a seating agent for the transducer, I can assure you it does.
    Cheers
    Jake
    1996 Z210 Shabah
    Mercruiser 5.7LX
    Alpha One Drive
    Old 06-20-2016, 08:43 PM   #20
    Heckman15 is currently offline
    My Model: Z250
    My Engine: 7.4L Bravo 1
    Send Heckman15:
    I know this is an old thread, but does anyone have a picture of where their Transducer mounts? I am a new owner of a 2001 Z250 and the only thing I can find I assume is for my speedometer (which doesn't work) that has a black plastic wheel.
    Depth finder inop theeasynine Original Mariah Talk 24 09-06-2010 05:45 PM
    Depth finder woes NogginDoc Boating 101 1 07-19-2010 04:35 PM
    Depth Finder Problem?? hatran Introductions 2 05-20-2010 06:18 PM
    Depth Finder works the first minutes then mad ebb8827 Original Mariah Talk 8 03-23-2010 03:52 PM
    Depth finder joeboat Original Mariah Talk 1 08-21-2009 12:54 AM
    Total Threads: 13,324
    There are 417 users
