Adding cleats to a 94 Davanti
1 Attachment(s)
Hi!
How difficult a job is it to add a couple of cleats to a 94 Davanti? See attached pic. I'd like to place a cleat on both sides at the location shown by the red arrow. I am guessing I have to remove the inside pads to access the side of the boat. How would one accomplish that task? Or is there something else I can do to tie a fender mid-ship, other than using a plastic clip or something? This (http://www.westmarine.com/webapp/wcs...classNum=10388) is the only option I can think of right now, if adding a mid-ship cleat is not easy. Thanks a bunch, guys. Sanu Attachment 3056 |
Re: Adding cleats to a 94 Davanti
4 Attachment(s)
The solution is much easier than a cleat. These are sold at West marine as well, and you can always leave the line attached to the fender and use on either side you need them on. Just mount two of these fittings on each side in the same place and problem solved. :wink_thumbup:
Zack,
Do you have to remove the inside pads to screw those into the hull? Sanu |
No, you just drill a nice pilot hole for the screw and screw it to the fiberglass. The screws are only 1" or so. You want the pilot hole so you do not crack the fiberglass though.
Just my $ .02 worth here.....
What Zackattack suggests are easy to install and super easy to use, but in my experience (two diff boats) using these while rafting up with other boats, the fender while doing its job gets pinched between the boats, and during the "bobbing up & down" motion the fender stays put and little tab works its way up and out of the holder, and off your fender & line floats. Installing a real cleat is easy. Your inner pad simply lifts off. A gentle upward tug (two people is best) or on a stubborn one a firm tap upward with your palm, will give you access to thru bolt a cleat. A very easy and quick solution with a permanant fix. |
Hi Zack,
please check the How to's section in our forum. http://www.mariahownersclub.com/foru...ra-cleats.html although it looks easy just to screw the cleats on to the boat, best is still to ensure you have a correct backplate at the other side of the hull. That will reduce stress and cracks appearing in the gel coat later. Kindest regards, Johan |
Great info on the support and drilling techniques. Thanks.
Northwoodz, I did not know that the inner pads could be lifted off that easily. Is that for all Mariahs? Even the 94?
Johan, great documentation on how to install those cleats. Although for my boat, I have the regular Herreshoff cleats. So it would be closer to drilling the screw holes (if I can gather courage to do it myself). But I would prefer to have a backing on it behind the fiberglass, just for added protection. Although I am not sure if the factory ones have any wood/block backing behind the fiberglass layer. Sanu |
3 Attachment(s)
Guys,
I finally managed to install the mid-ship cleats on my Davanti. I installed regular Herreshoff Cleats as they are what I have on the bow and stern. Attached is the procedure I used to do it. Just in case someone else needs it. Also attached are before and after pics of the mid-ship area. Thanks guys for all the advice. Cheers! Sanu Attachment 3103 Attachment 3104 Attachment 3105 |
| All times are GMT. The time now is 01:12 PM. |
