Parts for Z308 searching
Hi @ all
We need for our Z308 the table inside cabin and the front leather part for building the bed. Thx best regards Wolfgang |
that....could be tough to find. :(
you may have to custom make those items but someone else here might know of something somewhere.... |
Thank you:) |
Hi topgunwolf, What year is your Z308? You can try and contact member "[email protected]", he's listed as owning a 2001 Z308. Try sending him a PM @ http://www.mariahownersclub.com/foru...do=newpm&u=120 and if he responds, see if he has the same table and if it has a manufacture's name on it anywhere. He might be able to provide some pictures for making a new one including the part for the bed if need be. Good Luck and let me know, WetWilly |
Willy's on the ball! Good thinking!!
Its a 2000-2001 in nearly bad conditions inside:punch_out:, but the engines are well and also the hull:yes_grin:. greetings from austria Wolfgang:wink_thumbup: |
Hi topgunwolf,
Have you tried to contact member "[email protected]" yet to see if he can assist you with restoring your yacht? He may have owner documentation as well. WetWilly |
Hi Willy
yeah i did, but he has the same problem as we have - missing nearly the same parts,... :eek_animated: Bad luck:mad: Greetings:D Wolfgang |
West Marine sells both the table tops and the post for the cuddy. It is made my Todd Enterprise. I just bought the setup for my Z255 it uses the "posi lock" system, looks good, cost was about $125
topgunwolf, check the floor mount for your tables and if you find a threaded post sticking up from inside of the hole, you have the "Posi-lock" system from Todd Enterprise as well. With the Posi-Lock system, the table post threads into the floor mount preventing it from coming out incase of rough seas or if someone bumps into it. The top mount (part under the table) just slides over the top of post. If you decide to make or purchase a different table, the post and table mount are available separately from West Marine. Posi-Lock post 26" high (floor to table bottom) - West Marine # 138797 ( Contact them to see if other heights are available too) Cost: $27.99 US - See link below: http://www.westmarine.com/webapp/wcs...key=SiteSearch Mount - Table pedistal - West Marine #138789 Cost:$21.99 US - See link below: http://www.westmarine.com/webapp/wcs...key=SiteSearch Unfortunately, there's the shipping: http://www.westmarine.com/webapp/wcs...4§ion=care Good Luck, WetWilly |
| All times are GMT. The time now is 10:19 AM. |
