-   -   Electric Hatch Lifts (http://www.mariahownersclub.com/forum/original-mariah-talk/5390-electric-hatch-lifts.html)
ShabahZ280 04-27-2011 07:49 PM
To those who've actually got functioning electrical hatch actuators for lifting the rear sundeck/engine cover, can you all check it and see if there's a specific model number on it? If so, let me know. This has been a pretty hot topic recently, so I'm trying to compile a list of the boat models and the actuators that were used for each. If you've got photos too, please post!
Here's the info I need!
Year:
Model:
#of Actuators:
Actuator Model#:
Thanks guys! :wink_thumbup:
Steve91T 04-27-2011 10:01 PM
Re: Electric Hatch Lifts
When I get mine back, I can help you out. May be a week or so :(
Zackattack 04-28-2011 01:02 AM
4 Attachment(s)
1994
Z212
2 actuators
Accu Lift MQ347 PV24183Q 12VDC
heres a couple pics.
I have had some struggle with them activating at the same pace as well as some other threads indicate. They took a lot of grease, and that helped alot. Checked all wiring and no issues, so I ran a 2 wire ckt to the dash and put a toggle switch in to intercept one of the rams on the way down to let the other one catch up. That was my solution for the difference in speeds and that seems to work great. They are still pretty slow though.
Attachment 3010
Attachment 3011
Attachment 3012
Attachment 3018
Reed Hatch 04-28-2011 02:17 AM
I have working ones on my 1996 z252. Do you want the serial number on the motor?
harrisdm 04-29-2011 10:17 PM
Hi Chris,
Electric Hatch Lift info below:
Boat: 1999 Mariah Z302
No.Lifts: Single
Cylinder travel: 12"
Gear Drive Manuf: Acculift Inc.(no numbers)
Info on motor: Fasco 2809-540-060 (manufactured in Canada)
Lift is Mariah original equipment(with lots of repairs/maintenance).
Don
Reed Hatch 04-30-2011 09:28 PM
1996 Z252 Shabah
2 Actuators
MQ347
PV24188Q
Acculift Inc
Made 29/8/95
DMK 05-07-2011 12:07 PM
My 1994 Z212 has two lifts on the rear deck. I can not read the name or model numbers, but they do not look anything like the ones in Zackattack's thread. Mine is more in-line, does not have a gearbox on the side. One side works, the other does not. I have both cylinders disconnected right now. Manually lift the deck and prop it open for now. Right side cylinder works fine. The left side will not work. I removed it and tore it apart in the shop, no problems seen. Hooked it straight to 12 V and it worked fine. Hook it into the boat wiring and it does not work. The voltage going to the cylinder is around 9 V. Battery is fully charged and I can hook the lift straight to the battery and it works fine. Will take pictures and post later.
Any Ideas?
Zackattack 05-07-2011 03:14 PM
HAs to be the wiring. I would see if you can get to the connection where it splits from one side to the other and redo that connection. If not, abandon that line and run a new one from the right side cylinder to the left in a new line. Its likely a bad connection though. Maybe even the quick connect at the cylinder.
DMK 05-08-2011 01:46 AM
Thanks for the help. I'll check connections and wiring.
z275st 05-08-2011 03:16 AM
1 Attachment(s)
Chris,
I had to order a new one in 2006. I found a distributor from this site and had to order through him. I can't find any paper work from then.
CAT Series - SKFLinearmotion/Products/Actuation systems/Linear actuators
Hope this helps.
