Electric Hatch Lifts
Old 05-09-2011, 07:21 PM   #11
edward cossey is currently offline
Status: Ed Cossey ( sonny boy )
My Model: 1998 Z252 Shabah Mercr
My Engine: 7.4L Bravo 111"
Gallery Images: 4
Default Re: Electric Hatch Lifts
Hi guys
when i bought my mariah the lift motor was disconected and seized, i stripped it down and freed up the bearings and it works ok, the wiring connection to the motor is just two wires i connected them up but the motor does not work, i dont know if the motor has to have a seperate ground or not , also the bottom bracket is missing,so does any one got any ideas on the connections and bracket, i am using gas struts at the moment the seem to work pretty good but i would like to fit the lift motor because thats the original spec.
ed cossey
  • Old 05-10-2011, 06:02 PM   #12
    tmonson is currently offline
    Status: Silver Contributor
    My Model: 1999 Z272 Shabah,
    My Engine: 7.4L Bravo 3
    Mine failed years ago. It was slow and noisy so I updated to a hydraulic ram. I pruchased a used trim motor and pump and installed a hydraulic cylinder in place of the old electric unit.
    Works quiet and fast now. Nothing against the electric model, I just wanted to be different!
    Thank you tmonson for this useful post!
    edward cossey (05-10-2011)
    Old 05-12-2011, 03:06 PM   #13
    Marsh is currently offline
    My Model: 225 Davanti
    My Engine: 350 Mercruiser Bravo I
    1995 Davanti Z225
    Old 05-13-2011, 08:45 PM   #14
    jr2562 is currently offline
    My Model: Z200
    My Engine: 4.2L
    Hi, does anyone have the wiring diagram for the hatch switch (6 connector)?
    Joe
    Old 05-23-2011, 04:00 AM   #15
    Buddy is currently offline
    My Model: Z202 shabah
    My Engine: 5.0 mercrusier
    Gallery Images: 1
    I thought one of the hatch lift motors was going out so I switched the left motor for the right. It turned out to be the wire connectors so I replaced them with insulated spade connectors and they both work fine now.
    Old 02-02-2012, 08:42 AM   #16
    cp55 is currently offline
    My Model: z220
    My Engine: 5.7 mag/ alpha 1
    Thanks for the pics and the info. The pics were great I have a z220 and this is the exact application i have. They both work but I have been redoing some things and have been working on the wiring by the switches.
    Old 02-04-2012, 03:05 AM   #17
    My Model: Shabah 238
    My Engine: 5.7 Alpha1
    I was reading through this and thinking "Hydraulic would be so much better" but it looks like Tmonson beat me to it. The hydro would be almost maintenance free, and you wouldn't have the issue with one side going up faster than the other. Might look into doing mine in the spring, and put together a tutorial if it works out okay.
    Old 02-06-2012, 11:15 PM   #18
    My Model: z220
    I have just got mine working (both of them) checked wiring etc. and they are now functioning. I was going to check the numbers but they are identical to the ones Zackattack has shown. I have a 1994 z220.
    prestige trailer W/Electric brakes karmann Original Mariah Talk 3 05-18-2010 06:38 PM
    Boat lifts and weights jdecoudres Sea Fox - Mariah Talk 3 04-06-2010 01:36 PM
    Looking for an electric antenna for my z-252 wayne344 Requests 2 09-23-2009 09:57 PM
    Electric fuel pump for carbed 350 Hyperryd Original Mariah Talk 4 07-26-2009 12:49 AM
    where can i get a new electric hatch opener pops k Requests 2 06-09-2009 02:42 AM
    Total Members: 6,945
    Total Threads: 6,286
    There are 39 users
