-   -   A few end of season projects (http://www.mariahownersclub.com/forum/original-mariah-talk/5033-few-end-season-projects.html)
theeasynine 11-03-2010 11:48 PM
I thought I would share some after season projects with everyone that we did.
First my dad and I used a 3 stage Meguiar's Fiberglass restoration kit. It took about 2 solid days in all. It definitely took a few years off the ol boat.
http://i58.photobucket.com/albums/g2...asynine/m3.jpg
http://i58.photobucket.com/albums/g2...asynine/m4.jpg
The next project we installed a new Sony cd player since the old one did not work. The left rear speaker was still not working after the install so we traced the speaker wire and found it had been cut off so we ran a new wire to it. I also added a speaker in the bow which wasn't too hard to do. Also we added a horn switch next to the power seat switch since for whatever reason there was no horn switch when we got it.
http://i58.photobucket.com/albums/g2...asynine/m2.jpg
http://i58.photobucket.com/albums/g2...asynine/m1.jpg
I was able to find new "Mariah" and shield decals for each side and I can't believe how much better it makes it look.
Befores
http://i58.photobucket.com/albums/g2...asynine/m5.jpg
http://i58.photobucket.com/albums/g2...asynine/m6.jpg
Afters
http://i58.photobucket.com/albums/g2...asynine/m7.jpg
http://i58.photobucket.com/albums/g2...asynine/m8.jpg
Our last project is replacing the triangle piece of glass on the driver's side behind the window that opens. We got the piece cut at a local shop from tracing the opposite side and are now waiting for a way to fix it in place since the original gasket was missing.
So, how many days until spring???
Patrick
mikeyt 11-04-2010 02:04 AM
Re: A few end of season projects
Can i send mine over ? ;)
Dredd 11-04-2010 04:44 PM
haha, Mikey.
Looks good, Easy. I always like to see how much difference things as simple as new decals make. Glad to hear more positive feedback on that restoration kit too.
theeasynine 11-04-2010 04:54 PM
There's room in the shop for one more :wink_thumbup:
michaelb 06-19-2011 12:25 AM
my passenger side window (the one that opens) fell out. interested to know what did you use to fasten/glue the staright side that doesnt open. i am thinking it is some sort of black caulking, i have heard the term butal tape but not sure if this is what to use or where to find it. any help wopuld be apprecited.
thanks
darkcalling 06-19-2011 01:32 AM
If you go butal tape any body shop supply should have it for something that small if you ask your glass guy real nice he might clip you the size you need was quite common for automotive windshields might still be but out of the bizz now so who knows with technology from the one I did on my old boat and a couple others I have seen that rubber gasket pice should be available to I would think just a guess though good luck looks great.
theeasynine 06-19-2011 04:25 PM
thanks
We used a foam roll since we couldn't find a gasket then used sealant caulk around everything.
michaelb 06-20-2011 10:27 AM
thanks , when you say foam roll I assume your talking about the products that have addhesive on one side?
theeasynine 06-20-2011 01:34 PM
Correct. It fits perfect.
