-   -   Fueling My 198SE (http://www.mariahownersclub.com/forum/original-mariah-talk/4960-fueling-my-198se.html)
Shabah 198SE 10-11-2010 06:55 PM
Fueling My 198SE
When fueling my boat, the fuel overflows before anything comes out of the overflow. In addition, there is no change in sound at the overflow to warn one that the tank is almost full. Is this normal for a Mariah?
My other boats have either made load blooping sounds at the overflow or discharged a bit of fuel from the overflow to warn you that the tank is almost full. This boat just gurgles from start to finish.
Shabah 198SE
Oregondunes 10-11-2010 07:34 PM
Re: Fueling My 198SE
try blowing some compressed air back down the vent. could have a bugs nest or something blocking it. make sure to remove the gas cap first to allow the air to escape
Shabah 198SE 10-11-2010 10:44 PM
Oregondunes,
Thank you for your response.
I will try something along those lines. What confuses me is that I can hear it gurgling from the vent and I can see vapours coming from the vent while the fuel is being added. The vent in four or five inches lower than the filler. I'll have to see if the vent hose is mounted/clamped higher than it should be as well.
Shabah 198SE
Oregondunes 10-12-2010 12:53 AM
that again might suggest that you have some sort of blockage, but not complete. Some air is escaping, but not quick enough before it overflows.
Shabah 198SE 10-12-2010 01:35 AM
Oregondunes,
You may be right. I hope to pull the boat out for winter on Wednesday and I will take a better look at things.
Thanks Again
Shabak 198SE
Cliff_Haskins 10-12-2010 08:31 PM
Don't be surprised if you find a "positive" loop of hose above the vent fitting, possibly collapsed/kinked.
Shabah 198SE 10-13-2010 01:37 AM
Cliff_Haskins,
Thanks for your response.
That may be the problem. I'm going to try to look things over tomorrow.
Shabah 198SE
Oregondunes 10-13-2010 06:41 AM
scary as this may sound, I filled my (128 gal) tank up tonite. it wasnt empty, but man did that ever leave my wallet light after.
Mine sputtered fuel out the vent just at the same time it splashed out the filler slightly.
Shabah 198SE 10-13-2010 12:15 PM
Oregondunes,
Ouch! I'm glad that my tank is about a third of that size. Even at that, I cringe at the cost.
It's about minus three Celcius today and I hope to get the Mariah out, winterize it and check out a few things. The frost on the roofs and in my ditch say that it is time. It is a bad sign when the neighbours are scraping their windows.
It would appear that Mariah's have a few refueling issues.
Shabah 198SE
Shabah 198SE 10-14-2010 01:27 AM
Well, the boat is out for the year, but I can see the probable cause of the fueling problem. The vent hose does not have a full loop, but it is looped up and fastenened to the underside of the deck at a point higher than the vent and almost equal to the height of the fill fitting. I will modify it in the spring.
Shabah 198SE
