Hatch closed, batteries dead, Help
Old 11-02-2010, 07:52 PM   #11
845paulg is currently offline
My Model: Shabah Z 272
My Engine: 7.4 L MPI Bravo III
Gallery Images: 12
Send 845paulg:
Default Re: Hatch closed, batteries dead, Help
Hello, you probably got the problem solved by now, but, if your center bench seat is on hinges and it folds down, you should be able to duck in at the front of the motor and pull the actuator pins located at the swim deck underside. Then you can raise the hatch manually and deal with your problem. Additionally, as one of the members mentioned, an on-board battery charger is a great idea. I just installed one as part of my restoration winter project on my 96 Z 272. I plug in the shore power with an adaptor so I can plug in to my garage outlet and pesto the charger is automatically maintains the batteries and then turns itself off once the batteries are satified.
  • Old 11-03-2010, 01:05 AM   #12
    scubydo is currently offline
    My Model: 200
    Send scubydo:
    Originally Posted by figaro View Post
    maybe a little late here .. but how about trying a trickle charge through cigarette / accesory socket
    That is the exact same thing I was thinking, but wanted to read all the posts before posting. It would be easy to do and you don't risk messing anything up.
    Old 11-08-2010, 06:23 AM   #13
    dmickelson is currently offline
    My Model: Z222 limited edition
    My Engine: 7.4 bravo 1
    Send dmickelson:
    I made up a cigarette adapter to trickle charge battery in off season. Leave battery switch on.
    My Mariah is dead domraga Original Mariah Talk 4 02-22-2010 07:16 AM
    Batteries jdecoudres Sea Fox - Mariah Talk 8 01-29-2010 01:16 AM
    Closed cooling system tet68 Mercury MerCruiser 1 12-09-2008 10:01 PM
    batteries dead can't open the back hatch mark keough Original Mariah Talk 4 07-13-2008 10:33 PM
    batteries dead can't open the back hatch mark keough Introductions 1 07-12-2008 04:04 PM
    There are 320 users
